Question about GE Home Security
GE Simon 3 door contact Where can I purchase a replacement?
Posted by Shirley on
cwradio73
  • 1,162 Answers
Call GE for parts. Sears also has repair service for GE.
Posted on Jul 19, 2017
  • cwradio73 Jul 19, 2017
    At Sears or call GE service parts
5 Related Answers
Anonymous
SOURCE: GE Simon 3 Add or Change a Sensor to my system?
You need to use an installer code to add/remove sensors. Depending on what number of digits your alarm code is set for will determine the number for the intaller code. Look in the installer manual for the code. Then follow these steps:
Open the panel.
Key in installer coe
Select Add
Select Sensor/Remote
Activate the sensor you want to add. Some sensors have a button, some have to opened to activate.
Choose sensor name and group. Groups are listed in the manual. Basically, if you want the sensor to arm when the doors arm (such as for a window sensor or door sensor) put it in group 10 or 13. If it's a smoke sensor, group 26; motion detector, group 17 and keyfob, group 01.
Press done when finished and run the test to make sure the system is reading the sensor.
Posted on Oct 09, 2008
Anonymous
  • 80 Answers
SOURCE: i have ge simon 3 which suddenly says phone not
you may have had a lighting strike to the phone line causing a surg to your unit. it may be fried. try completly powering down the system and powering it back up, then try to send a signal to your monitoring station. also you my have your monitorimg station try and connect to your system and check the programing it may have been scrambled.
mj
Posted on Sep 01, 2009
russvan
  • 74 Answers
SOURCE: I have GE simon 3 - Purchased ION MICRA -G
The Micra sensor does not have a "tamper" which is the method that is used to enroll GE transmitters. Both the Micra-G and Plunger-G transmitters send a tamper signal when the battery is inserted.
Note: It takes about 4-8 seconds for the tamper to be transmitted as the switch boots up.
Note: If you are removing the battery to re-insert it to boot up the switch, first short the + and - terminals on the battery clip to dissapate the charge on the current saving capacitor. Just removing the battery will not dissapate the capacitor and if the capacitor is still charged it will not reboot and send a tamper signal. - AlarmProfessor.net
Posted on Aug 23, 2010
russvan
  • 74 Answers
SOURCE: ge simon 2 alarm no longer beeps after battery replaced
Probably knocked off the clip on the piezo. Open the box and make sure all plugs are plugged into the circuit board.
AlarmProfessor.net
russvan
  • 74 Answers
SOURCE: Trying to add 10 window sensors to existing GE
First you need to have the installer code. Open the fromt panel of thealarm and enter in "4-3-2-1" (Default installer code) If it accepts this number then you can begin to program the doors and windows. If you don't knowtheinstaller code you mayneed to default the system and reprogram everything. If you contact meIcan walk you through the processor.
AlarmProfessor.com
Posted on Sep 05, 2010
Can any wireless door or window sensor be used with the ge simon
Sad to say but other brands of wireless door and window sensors will not work with the ge simon. Other sensors has different command patterns that it will not recognize the command coming from the GE Security Simon 3.
Nov 02, 2010 | GE Security Simon 3 Wireless Home Security...
Trying to add 10 window sensors to existing GE Simon 3 control panel that currently has just motion detect, glass break detect, and 3 door sensors. How to install and program them to work? Thanks you,...
AlarmProfessor.com
Sep 03, 2010 | GE Security Simon 3 Wireless Home Security...
I have a GE Simon XT. I arm the system. When I return several hours later, the front door doesn't beep when I open it. I have to close/open it again to register. Front door is Sensor 1, Group 10. What...
Can I assume it is a wireless contact we are talking about?
1.) Low battery in tansmitter. Does your keypad display a low battery trouble? If so, ensure you put system in test before replacing battery as not to generate a tamper alarm when opening contact.
2.) Relay in transmitter is sticking. Replace wireless contact.
Stewart
May 26, 2010 | GE Security Simon 3 Wireless Home Security...
I have ge simon 3 - Purchased ion micra -g wireless window and door compatible sensors. Didn't come with how to add sensor. Wants me to push button on sensor; where is that button
I'm having the same problem on a used Simon. I think the button is inside the wireless transmitter. It has a spring attached to it. Just press on the spring to send wireless signals to the panel. My problem is I press on the spring and the panel does not receive the signal, even with a $20 fresh Lithium Ion battery from Radio Shack.
May 15, 2010 | GE Security Simon 3 Wireless Home Security...
Unresponsive door sensor--Simon 3
If it is a newer model there are several setting as to which reed switch you are using or if you are using the wired option. Contact the professor.
AlarmProfessor.net
Sep 04, 2009 | GE Security Simon 3 Wireless Home Security...
I have comcast broadband and am thinking about purchasing the GE Simon 3 system - will it work with broadbanc VOIP
more than likely it wont work, security system were designed to work on annalog phone lines aka potts lines. you can with added eq. monitor any security panel than can transmit contact id format over the cellular network.
mj
Jul 22, 2009 | GE Security Simon 3 Wireless Home Security...
Repair parts for simon 3
Try eBay. Look for any of the following keywords:
"GE Simon"
"ITI" (that's eye-tee-eye, for Interactive Technologies, Inc. original developer of Simon, now a subsidiary of GE Security)
"319.5" (the frequency on which simon sensors operate).
You'll find almost any sensor you can imagine there.
Feb 15, 2009 | GE Security Simon 3 Wireless Home Security...
Home Security Logo
112 people viewed this question
Top GE Home Security Experts
Sean
Are you a GE Home Security Expert? Answer questions, earn points and help others
