Re: My canon mp360 scan`s all doc`s as a PDF how do I...
You need to save the scanned document as a jpg image file and then open an OCR program to convert this jpg file into a text file that you can open with WORD program.
ALSO There are some free programs (PDF to Word converter) on the Internet that can convert a pdf file into a Word document. This WEB site has a PDF converter program. http://www.pdftoword.com/
You can't post conmments that contain an email address.
The message indicates that the printer door or the cover located on the top is not closed properly, so you need to re-open the door or the printer cover and close it accurately.
<p><span>Manual Reset procedure Waste Ink Tank for Canon MP390 and Canon
MP360 Just Follow these steps to reset waste ink tank:</span><br />
<p><span>Start with printer on, press additional
functions, Scan, Copy, Scan. Now you should be in service mode.</span><br />
<p><span>Select Test mode which is like the last
available selection</span><br />
<p><span>Select #8 Printer Test, it will do something
here like cleaning or something then it will come up with some other option
this is where it gets a bit confusing cause now all it says is like 8-2 or 8-3
push the + or - button until it says 8-3 then hit the select button</span><br />
<p><span><span>·<span>
</span></span></span><span>The menu will now say EEPROM Clear</span><br />
</span></span></span><span>Select Ink count which is option (0) and press set</span><br />
</span></span></span><span>Then press Stop/Reset Followed by the power button and then wait
for it to restart.</span><br />
One thing to check and be sure of is that your printer cable (USB) is definately a USB 2.0 cable. Canon have an issue with their printers with scanners in that the data flow sometimes isn't sufficient when an older USB cable is used. The slightest drop of data on startup or during scanning will cause a stop.
Worth trying and has sometimes solved the problem for my customers.
