HP LaserJet 2820 Printer Logo
Posted on Mar 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
RdaShowing scanner error 3 and sometimes error 2. what is the code of error for? do i have to replace parts or it can be solved by software?
Anonymous
Level 2:
Guru:
  • Expert 89 Answers
  • Posted on Mar 27, 2011
Anonymous
Expert
Level 2:
Guru:
Answers
89
Questions
0
Helped
30213
Points
275
You can call HP Support to take advantage of your unit's warranty
or check
Guided Troubleshooting
http://h20584.www2.hp.com/hpgt/guides/select?lang=en&cc=us&prodTypeId=18972&prodSeriesId=445194
HP Color LaserJet, LaserJet and LaserJet MFP Products - 49 Service Errors
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=445194&prodTypeId=18972&prodSeriesId=445194&objectID=c01558499
Customer Self-Repair Steps (videos/animations)
http://h20464.www2.hp.com/csr.htm?prodSeriesId=445194
Hope I help you a bit.
Your's Truly,
Christian from HP
How do you replace the scanner cover oh the hp fax machine model 920
HP LASER PRINTERS 2, 2D, 3, 3D
1. Defective cable laser scanner to dc controller.
2. Defective laser scanner assembly.
HP LASER PRINTERS 2P, 2P+, 3P
1. Bad scanner motor.
2. bad dc controller.
HP LASER PRINTERS 3SI, 4SI, 4V
1. Faulty cable assembly.
2. Scanner motor problem.
3. Defective laser scanner assembly.
4. Defective dc controller.
HP LASER PRINTERS 4, 4+, 5
1. Faulty laser scanner cable.
HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
1. Temporary error. Scanner startup failure.
2. Improperly fitted scanning assembly.
3. Scanner cable problem.
4. Defective laser scanner assembly.
5. Defective dc controller board.
HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
1. Temporary error. scanner rotation error.
2. Replace contact image sensor.
4. Replace laser scanner.
5. Replace cables to laser scanner and engine board
HP LASER PRINTERS 1100, 2100, 4000, 4050, 8000
1. Scanner start up error
2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
3. Replace scanner ***'y.
4. Replace the engine board.
5. Replace the D.C. controller only on the 8000.
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
HP LASER PRINTERS 4200, 4300 ERROR 52.XX
1. Printer scanner speed error has occurred.
2. Replace laser scanner ***'y
3. Replace the D.C. controller ***'y
HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
1. Error code K - No Black Color.
2. Error code C - No Cyan Color
3. Error code M - No Magenta color
4. Error code Y - No Yellow color
5. Replace laser scanner ***'y
6. Replace the D.C. controller ***'y
HP LASER PRINTERS 5000, 5100
4. Replace cable ***'y from scanner to D.C. controller.
HP LASER PRINTERS 8100, 8150
1.Laser scanner error/start up/rotation error
2.Replace laser scanner ***'y.
3.Replace D.C. controller board.
4.Replace cable ***'y from scanner to D.C. controller
HP LASER PRINTER 4500, 4550
1. Temporary error. Laser scanner error/start up/rotation error
2. Replace laser scanner.
3. Replace D.C. controller ***'y
HP COLOR LASER PRINTERS 4600, 5500
1.Laser scanner error/start up/rotation error.
2.Take the toners out and reseat them, or replace them
3. Replace laser scanner ***'y
4. Replace D.C controller board.
HP LASER PRINTER 8500, 8550
2. Replace laser scanner motor.
HP LASER PRINTER 9000
1. Temporary laser scanner error/start up/rotation error
3. Replace upper cable guide assembly.
4. Replace DC controller.
1helpful
Cannon scanner is showing code 5,156,69 error how to solve the problem
It usually concerns the scanner: "Code:5,156,61 Cannot scan for these reasons: -Scanner is turned off.-USB cable is disconnected" Solution 1: check USB connection Try another USB port on the PC If USB cable is connected to an USB Hub: connect diretly the cable to the PC. Try another USB cable
Solution 2: Sometimes, an antivirus or the firewall of Windows can block the use of Canon software. Check this point by disabling them temporarily.
Solution 3: Reinstall the drivers of the printer
https://community.usa.canon.com/t5/Printer-Multifunction-Support/Error-Code-5-156-69/td-p/91792
How to solve Error Code: E100 0000 of canon LBP3150
Dear its indicate Laser/Scanner unit failure.
check
1) Turn the power off and on.
2) Make sure that the Laser/Scanner unit and DCNT board are
properly connected.
3) Make sure that the Laser/Scanner unit and DCNT board are
properly connected.
4) Make sure connections of the boards (power supply board
DCNT board and SCNT board
Replace the Laser/Scanner unit.
Thanks.
5120 code error
Any of these error codes (51.20 51.21 51.22 51.23) points to a failure with one of the laser scanner assemblies on the HP Color LaserJet 4610 an 4650 series. To solve these error codes, replace the corresponding laser scanner. Sometimes when the laser scanner fails you will also hear loud noises (often higher-pitched noises like screeching sounds); the noises can be another sign that the laser scanner needs replacing.
51.XY
PRINTER ERROR
For help press
alternates with
51.XY
PRINTER ERROR
A printer error has occurred.
X Description
1 beam detect error
2 laser error
Y Description
0 no color / black
1 Press to continue.
2 Turn the printer off and then on.
3 Reseat the connectors between the
laser/scanner and DC controller PCA
(J1009 - J1012).
4 Replace the defective laser/scanner
assembly. Calibrate the printer after
replacing the laser/scanner.
2helpful
My machine is ricoh FT 4220. error 11 or E1
E101: Exposure lamp error
1- check the Exposure lamp if it damage replace it .
2- check the Exposure lamp fuse ( located in scanner )
3- check the Exposure harness .
and after you solve your problem you must
Enter SP5-810 (SC code reset) and press the Enter key to reset the code
5helpful
Hp laserjet 3055 has code 52 scanner error and wont print or copy
PRINTER ERROR The laser scanner speed is incorrect. X description: 1 = Scanner startup error 2 = Scanner rotation error 1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner.
Scanner error 5
This error normally comes when the Step Motor is Defective. It needs to be repaired. It is a Part associated with the Scanner Assembly. But before going for repair, try to re-install the Driver and the whole software of the printer. This may also solve the problem.
Thank you Sir, Have a nice day.
4helpful
5answers
52 scanner error
HP LASER PRINTER ERROR CODE 52 – INCORRECT SCANNER SPEED ERROR
2answers
Error in Scanning
Sorry to ask u ,how old it is,this kind of problem is found due to following reasons
1)driver software:uninstall n reinstall driver
2)scanner is dusty:clean the scanner from inside
3)inner scanner cable(black cable) defective:replace cable
but before all try this
1)go to my computer,u can see icon of scanjet 2400
2)right clk,clk get pictures.....,new window will open,
3)click preview n wait n see does it shows the preview?
4)if it shows preview then reinstall hp director,or try above mentioned steps,definately the problem will be solved,
thnx
13helpful
4answers
SYSTEM ERROR E100
Hey
How can I solve this error code(IR1600) on my canon copier by myself?
k24674
Grand Canyon Tech
Grand Canyon Tech
