Question about Cannon Office Equipment & Supplies
It usually concerns the scanner: "Code:5,156,61 Cannot scan for these reasons: -Scanner is turned off.-USB cable is disconnected" Solution 1: check USB connection Try another USB port on the PC If USB cable is connected to an USB Hub: connect diretly the cable to the PC. Try another USB cable
Solution 2: Sometimes, an antivirus or the firewall of Windows can block the use of Canon software. Check this point by disabling them temporarily.
Solution 3: Reinstall the drivers of the printer
https://community.usa.canon.com/t5/Printer-Multifunction-Support/Error-Code-5-156-69/td-p/91792
Posted on May 21, 2019
SOURCE: Twain error on cannon scan D646U on VISTA
The D646U is not compatible with Windows Vista. Call Canon and inquire about their Customer Loyalty Program. They let you upgrade to a more current scanner at a reduced price.
800-828-4040
Posted on Jul 09, 2008
SOURCE: mp160 e42 error
hi,
CANON PIXMA MP160 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
mbhd2
Posted on Sep 05, 2009
According to you your scanner not working well which error code 2,114,0.
To solve this you can try the following
unplug cable
press and hold "power" button
plug cable
press "resume" and release
release the "power" button
At this stage, your computer will detect a new hardware.
Insert the the driver CD and update the scanner driver.
It may happens also for empty cartridge of also.
Replacing of your empty or dry ink cartridge can solve your problem.
