This should point you in the right direction...
Is this printer set for the default? have you rebooted? (Sometimes my pc needs a reboot to find the wireless printer)
Have you checked your hardware profiles to see if there are any error messages in the hardware profile?
Are you certain you have the right driver for the version of windows you are using?
Best regards
Ck
If you have a wireless router with a wireless network then -
Configure the IP address your wireless
printer, (this is done through the printer's menu settings) make sure it
matches the IP address range on your wireless network, it maybe 192.168.1.***
then configure the wireless printer with a fixed IP address with the same IP
address range but at a higher address eg. 192.168.1.10 so it does not clash
with any other IP addresses.
Next install the printer driver normally.
Then configure the printer Properties.
Click Start - Printers and faxes - right click on the your printer - click
Properties - Port tab - click Add Port - Standard TCP/IP port -
Port Name eg. 192.168.1.10
Printer name eg Network printer
Click OK
Then do a TEST print if it does not work then the IP address is probably
incorrect.
