20 Most Recent Canon PIXMA MX340 Wireless Office All-in-One InkJet Printer Questions & Answers
I have a Canon MX452 All in One. I keep getting this error message, code 5,157,69, cannot scan. What can I do?
Canon PIXMA... | Answered on May 09, 2019
What is error code 5100 on the MP460? - Canon Community
community.usa.canon.com/t5/Personal.../What...code-5100.../103212
Jul 7, 2014 - Please remove foreign objects so that the print head holder can move: ... closet and hooked it up this morning, I was getting the 5100 message.
How to resolve error 5100 on an MX452 / MX459 - Canon
https://support.usa.canon.com/kb/index?page=content&id...
There are several reasons for error 5100 to appear. ... If the above recommendations donot help you resolve the error, the printer will need to be repaired.
How To Fix Canon Printer Error 5100 - YouTube
? 2:23
https://www.youtube.com/watch?v=rJQVwwRxPv4
Mar 14, 2013 - Uploaded by ITJungles
Learn how to fix the Canon printer error 5100, and have your printer running again. ... Reset error Canon ...
Canon PIXMA... | Answered on May 07, 2019
I had the same problem with my MX340. I called canon and it turns out that something have falling in the paper tray. tilt it to the back and stick your finger in there and try to move the rollers or shake and tap it a little till it falls out. I had a little nail in there. it's working find now.
Canon PIXMA... | Answered on Nov 27, 2018
I had the exact same problem. The Alarm light was always on and the screen said "Document in ADF. When I pressed "OK" it would read "Eject the document". Even after I placed paper in the ADF and the paper would feed the document through it, the error and the Alarm light was still there. I found the solution, Lift the cover to expose the flat bed scanner glass. Under the cover, there is a long white bar with two white tabs perpendicular to the white bar. One of the tabs was retracted. Pull on the tab until it is fully extended. The alarm turns off and there is no longer the error. Simple solution to a damn annoying issue.
Canon PIXMA... | Answered on Jun 20, 2018
Please read for PDF manual for Canon PIXMA MX340 Wireless Office AllinOne InkJet Printer.
Canon-MX340-Multifunction-Printers-manual
or Download Here
I hope usefull.
Canon PIXMA... | Answered on May 05, 2018
Printer canon mx347 check in u051col blk
Canon PIXMA... | Answered on Dec 11, 2017
I had the same problem...after trying everything suggested on the forum. I had enough and decided to disassemble the printer. I removed the CAD and disconnected the wires and it solved the problem. No more paper jam error code on the screen. This probably includes that the CAD won't work anymore but I never used this anyway. So now I can print and scan like I used to.
Canon PIXMA... | Answered on Aug 28, 2017
Uninstall and reinstall the software. Corrupted software can cause all sorts of weird issues.
Canon PIXMA... | Answered on May 30, 2017
You MUST put in the password of the router in or it will never connect. Pressing a number key several times quickly should change the number to letters.
Canon PIXMA... | Answered on May 16, 2017
Removing the covers is not the answer. Most jams on rear feed printers/faxes are due to some object falling in the sheet feeder. When you pull the paper back out (Very slowly) of the sheet feeder after it has jammed , you will see a nick in the paper. This is because the paper is hitting something and cant get past it. put the paper back in the sheet feeder and the nick will indicate where the object is. Find a large paper clip and unwind it and bend the top of it to 90 degrees. use this to hook the object out and then tip the printer upside down and watch it fall out. Good luck
Canon PIXMA... | Answered on Dec 11, 2016
canon mp navigator will not open
Canon PIXMA... | Answered on Mar 30, 2016
See: http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/#5200
5200/P08 - Orange and green light blinking 8 times Description:
A service error has occurred.
Resolution:
  1. Turn off the printer.
  2. Disconnect the power cable.
  3. Open the printer cover.
  4. Check for any orange protective tape or white polystyrene and remove if necessary.
  5. Check that there are no foreign objects in the printer (such as a paper clip) and remove if necessary.
  6. Close the cover.
  7. Reconnect and turn on.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility using the link at the top of the page.
Canon PIXMA... | Answered on Mar 20, 2016
Canon i550 Service Error 5100 ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/25975
Oct 6, 2006 - I recently dropped my printer out of my car by accident, and now everytime I try to print something, it gives me a Service Error 5100.
Canon Pixma MX420 Printer 5100 Error and Loading Ink ...
? 5:57
https://www.youtube.com/watch?v=tmTJdJTAhYU
Mar 13, 2012 - Uploaded by Dustie Meads
please help me,i have problem in my printer,wifi on printer can't search .... I too was given the generic "5100" error message just tonight.
Canon PIXMA... | Answered on Jan 05, 2016
Canon PIXMA MX340 Wireless Office All-in-One InkJet Printer Logo
614 questions posted
Clive
Clive
old marine
old marine
View Most Popular
PIXMA Canon
  • PIXMA Canon
Most Popular Question
canon mx340 airprint capable
  • Office Equipment & Supplies
