Kenmore Elite 45986 Front Load Washer Logo
Posted on Mar 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What does error code f71 mean? - Kenmore Elite 45986 Front Load Washer
Anonymous
Level 3:
  • Master 5,081 Answers
  • Posted on Mar 03, 2011
Anonymous
Master
Level 3:
Answers
5081
Questions
Helped
2236786
Points
18738
F71 means it is an Central Control Unit(CCU) communication failure.
http://www.fixya.com/support/r6709094-whirlpool_duet_f70_f71_error_codes
There is an detailed article by one of our senior experts in the above link.. Kindly look into the same.
GE range F71 error code and beeping
So F71 does mean that your touchpad is failing or one of the buttons is sticking. Try to unplug the oven and use a hair dryer to heat up the touchpad. Rub the buttons with your thumb in case one of them is sticking and then let the unit cool down. Plug the oven back in and if you still get an F71 error, the only thing you can do is replace the touchpad
My whirlpool cabrio washer wtw6200vwo shows f71code and wont spin out clothes
WHIRLPOOL CABRIO WASHER ERROR F71. The Cabrio Washer Error F71 code is the same as the SD code: This error means the main control board detects too much drag on the basket during the spin cycle.Mar 29, 2017
My washer is not operating properly. please tell me what code F71 means and how to fix the problem. Thank you.
F71 points at a connection error between button pad and control board.
Please read the indications in this article: F70 and F71 are two logic board error codes...
Regards.
3helpful
2answers
What does an F70 and F71 error code mean?
Hi.
Please read the tip below, explaining how to fix F70 and F71 problems. The comment applies to Whirlpool washers like the one in question.
F70 and F71 are two logic board error codes that point at a communication error between the main log...
Regards.
Ginko.
I have Kenmore HE5T Error code F71 Pls advise handling. Thanks.
Regards.
What does F71 mean ? This comes up half way through the cycle
Regards.
Error code shows F71. door is locked and there are clothes in there soaking in water that I need to get out!! what does F71 mean and how do if solve the problem
Hi.
Sorry for the late reply.
If you get similar problems in the future, and machine gets stuck in error mode with clothes inside, empty water from tub disconnecting the drain filter, located behind a panel in front lower side of appliance. After emptying water the door will normally get opened.
Regards.
There is an error code f70 and there was an error code f71.
Hi.
Please read the tip below, explaining how to fix F70 and F71 problems. The comment applies to Whirlpool built kenmore washers like the one in question.
Regards.
Ginko.
Alexander
vince
