Tip & How-To about Whirlpool WFW8300SW
Whirlpool duet F70 and F71 error codes.
F70 and F71 are two logic board error codes that point at a communication error between the main logic module and the control pad (user interface and CCU), and between the motor control unit and central control (MCU, andd CCU that is main control module).
Repair is difficult, as motor, wiring and voltages from control modules must be tested.
Try first doing a reset, by disconnecting power cord or tripping circuit breaker and leaving power off for five minutes.
If that does not help and errors come back, then the best thing to do is calling the service number listed on the user manual.
Here extensive explanation of error codes and relative troubleshooting:
F70: CENTRAL CONTROL UNIT HEARTBEAT FAILURE
If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the Central Control Unit to the User Interface.
1. Check for continuity of the User Interface harness.
2. Check wire harness connections to the User Interface and the Central Control Unit.
3. Replace User Interface if drum is rotating.
4. Replace Central Control Unit if drum is not moving
F71: USER INTERFACE HEARTBEAT FAILURE
If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the User Interface to the Central Control Unit.
4. Replace Central Control Unit if drum is not moving.
To get parts and diagrams try entering the full model number in one of the websites below:
Enter the model number ..
To contact a repairer, call the number listed on the owners manual or use the Fixya directory (US only)
Whirlpool WFW8300SW Logo
I have a front loader MHWE3000VW12 it's giving me a code F70 Ineed to know what it means
Thanks
Jul 26, 2012 | Maytag Washing Machines
Whirlpool duet getting error code F70 and F71. When hitting start button, getting a clicking sound and nothing is happening. Cannot open the washer door as it is locked with clothing inside it.
Hi jreib29,
Hope this helps.
Thank you for using FixYa.
Sep 17, 2011 | Whirlpool Kitchen Ranges
What do the following codes mean: F70 and F71. My washer is a Kenmore Elite HE5t. Thank you
The F70&F71 mean basically the same thing
F70 means the main control board is not communicating with the cycle selector/touch pad control
F71 means the cycle selector/touch pad controlis not communicating with the main control board
What needs to be checked is the wires between the main control(CCU) and the selector(user interface) for good tight connections
If all connections are good and tight the CCU has to be replaced IF the drum will rotate under power from the motor
OR if the drum will NOT rotate under power of the motor the USER INTERFACE needs to be replaced
Gene
Aug 18, 2011 | Kenmore Washing Machines
what is err 70?
Repair is difficult, as motor, wiring and voltages from control modules must be tested. Try first doing a reset, by disconnecting power cord or tripping circuit breaker and leaving power off for five minutes.
Hope this helps.
Aug 04, 2011 | Kenmore HE2 Plus Front Load Washer
18,291 people viewed this tip
Dan Webster
Dan Webster
Sal DeAngelo
