Computers & Internet Logo
Posted on Feb 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
"Go to any computer-store. Purchase an "empty"
Angel Libres
Level 2:
Guru:
  • Expert 196 Answers
  • Posted on Feb 06, 2011
Angel Libres
Expert
Level 2:
Guru:
Answers
196
Questions
10
Helped
26122
Points
541
You did not explained your problem very well. How can we help you. Please elaborate.
The usb port on the enclosure broke off and is now on the end of the usb cable.
Purchase an "empty" external enclosure, and "transplant" the disk-drive from your MyBook into the empty enclosure. All your files will be intact.
My Beyond Macro External hard drive model no BMMDU2 has stopped working.. It shows up in list of "Safely remove Hardware" but windows XP professional SP3 is not assigning any letter to...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Ubs pin broke
If the warranty is still valid, ask W.D. if they will repair it.
If not, open the enclosure, remove the disk-drive.
Buy a new "empty" enclosure ($30 to $50 at any computer-store), and "transplant" your disk-drive into it, to preserve your data.
The piece that allows a usb cord to connect to the actual external hard drive broke off and i no longer can plug it into my computer. how do i get the piece out or fix it?
* the USB cable
* the power-adapter
Or, buy an "empty" external disk-drive enclosure, for about $30, and "transplant" your disk-drive into this enclosure.
3helpful
Not recognizing the hard drive, originally my P/C said it was a cable problem. Where can I purchase new connections & ac adapter?
* the USB cable
* the power-adapter
Or, purchase a new "empty" external storage device (with AC adapter), and "transplant" your current disk-drive into this case.
Note that W.D. has a "Customer Loyalty" program -- you can buy a new W.D. device, through the W.D. web-site, at a significant discount.
Usb input broke need replacement
Go to any computer-store. Purchase an "empty" external disk-drive enclosure & power-supply.
Then, open your "old" enclosure, and remove the disk-drive from it,
and "transplant" the disk-drive into the "new" enclosure.
Hi. I have lost my adapter and connectors to connect my smart disk HD to my Macintosh power book (g3 model). The model # on my disk drive is FWFL80-N. Has another # which is JH7X04. Where can I find...
You could buy a disk-drive-to-USB adapter, and connect the "bare" disk-drive to a USB port on your computer, and then copy all the files onto your computer.
See: http://cgi1.ebay.ca/ws/eBayISAPI.dll?ViewItem&item=190391564434
for under $5.00 for such an adapter.
Or, you could spend about $40 to buy a brand-new enclosure & AC-adapter & cable that is "empty", and then you could "transplant" your 40GB disk-drive into that enclosure, without losing any data on the disk-drive. Then, copy the files, and then remove the disk-drive, and purchase a new, larger, disk-drive, and install that into the new enclosure.
Given that your disk-drive is "only" 40GB, it's probably getting old, and is "out-of-warranty", and thus should be "retired" before it completely fails.
So, the best solution would be to buy a brand-new, much larger, external storage device.
Ac adaptor will not work
Go to any computer-store, and buy a new "empty" external drive enclosure.
Then, "transplant" the disk-drive from your W.D. enclosure into the new enclosure.
All your files will remain accessible, and the new power-supply will power your disk-drive.
I am using Fantom Titanium 250GB External (TFDU25072B) Hard Drive i am not able to formate it i am using Windows XP Sp2 its giving me error " unable to formate " even i am not able to formate it...
The disk-drive inside the enclosure is problematic.
Open the enclosure, to get the model-number and serial-number from the label on the disk-drive.
Then, access Fantom's web-site, to check the warranty-status of the drive. If the warranty still is valid, they will replace it, at minimal cost to you.
If the warranty has expired, purchase a new, compatible, disk-drive, and transplant it into the enclosure, to "resuscitate" your device.
1helpful
2answers
My Hard drive has only 6% space left on it.Can i connect external Hard drive to it?
> can I connect an external hard-drive to it?
Probably.
However, an external hard-drive should _ONLY_ be used to make an _ADDITIONAL_ copy of your important files. It should _NOT_ be used to store the _ONLY_ copy of some files -- if/when the drive fails, the _ONLY_ copy of those files will be _GONE_. Not good!
Instead, it's time to purchase an additional "internal" disk-drive, which will be _NEWER_ and _LARGER_ and _WARRANTIED_ and to use software to "clone" your old hard-drive onto your new hard-drive.
Then, disconnect the old, out-of-warranty, disk-drive, and boot Windows from the new disk-drive.
Then, purchase an EMPTY disk-drive enclosure, for about $30,
install your old disk-drive into the enclosure, to build your own external storage device. Once you're satisfied that your new "clone" disk-drive is working 100% correctly, delete all the files from the OLD disk-drive, and then make a backup of your files onto the now-empty disk-drive.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
