20 Most Recent HP 2x1x16 Kvm Ip Switch 16 Port 410530-001 408965-001 Questions & Answers
Can you give us more information, is the USB not working at all, and if so when did it stop working, if you go to device manager, are the drivers for your USB ports showing any issues.
HP Computers &... | Answered 9 hours ago
all computers are not recognize or only your system...
The HP support assistant is a bit of software that is pre installed on all HP computers, it helps you keep the drivers and other software up to date, it will also help you trouble shoot issues with the device ect, if you have lost the software due to a re-install ect you can download it from the HP web site
HP Computers &... | Answered 11 hours ago
it is always written bottom side of laptop... and front side or remove its battery and locate.
HP Computers &... | Answered Yesterday
BINGO SFF, small form factor model. and old ,
not just a tad old , OLD !
d530, is 16 years old. it will have many problems but sure dead. is bad deal.
do the 2 fans work PSU and CPU>?(spin and blow)?
first off the RTC coin cell is no good, at 16 years old, 3 times over in fact. 5-7 year is spec on CELL (hint below 2.9vdc is the cliff of ddeathh 3.3vdc is par)
next is filth, full lint blocking air flow in PSU and CPU for sure.
last is bad HDD.
I'd test the coin cell, below 2.9vdc is bad.
then reSEAT the RAM. sure gee even blow out the dust in the socket after 16 years of zero cleaning?
or run the 2 RAM sticks 1 at a time at bank 0 slot.
is this your PC this is MT. mini tower, of the 3 form factors made
https://support.hp.com/us-en/product/hp-compaq-d530-convertible-minitower-desktop-pc/316720
why not talk about the coin cell first a $1 part
and if the fans spin, seen heard and felt. to blow air fully,1621a0e8-633c-4358-9b42-00fa2f9ece4f.jpg
it means not connected with net or sharing only one system used..
this change will be made in file which you want increasing font....open file and locate setting on top
hello OP
yes, and is covered in you manual. at HP.com
HP 15 is not a full model number, stated so....
my guess not HP 15 ENVY. but to progress here, I will guess.
over 200 models with that short name exists.
huge models. I guess one is your?
https://support.hp.com/us-en/products/laptops/hp-notebooks/
you left out all those facts in the model.
but all modern HP , you CAN do this,
power on, and hammer f11, this runs the magic RECOVERY
that restores the OS to day 1, new, all data you created gone.
as the book says, and is true.
but if the HDD is bad (or molested or upgraded from other OS)
it ill fail.
read page 84
http://h10032.www1.hp.com/ctg/Manual/c06189781
3 years old?
here. but there are 85 models of F15 in this one class of PC.
the PC is not dead, has F1 screen in bios
called information screen.
power on, and hammer esc, key and see small menu (bios)
and click F1, behold the INFO page
the 1st 3 lines there, tell you model and p/n of the PC. all are very important but not serial numbers here, only hp can use serials
if need by.
HP Computers &... | Answered on May 17, 2019
barrow a mouse, billions everywhere on Earth.
NO PC stated full model.
but is Chrome browser and what OS, is the OS chrome or windows.?
tell what PC this really is first. maker HP model xzy123? what?
HP Computers &... | Answered on May 16, 2019
did you ask at HP.com first of google that, seems not.
to me.
omg first hit is correct
https://h30434.www3.hp.com/t5/Notebook-Operating-System-and-Recovery/0xc0000225-error-recovery-partition-won-t-boot/td-p/2914183
is not google great for searching?
if the answer in the link confuses you let me elaborate that.
it means (in order of causes common)
The HP recovery partition is dead. F11 key now DEAD.
that means:
1: HDD is dead. (weak or failing S.M.A.R.T tests )
2: the HDD was replace before and F11 is GONE
3: the HDD was upgraded to SSD, see #2
4: someone or virus wreck that partition F11 HP_Recovery.
HP Computers &... | Answered on May 13, 2019
Unless you have one of the very latest laptops, your model laptop most likely has a DVD ROM combo drive - which allows you to play DVDs and CDs also burn CDs/
You need to give me the make and model number of your laptop for me to verify if your laptop is capable of burn DVDs.
HP Computers &... | Answered on May 12, 2019
Hello Heko, it usually happens because of problems with the controller that intercedes between the software and the computer (in this case HP laptop or Desktop) and we can find the solution with HP Support Assistant's own tools.
Most blue screens are hdwr/driver relate, but would need more info on your setup to offer detailed advice.
For starters though, disconnect all external devices except the monitor (yes, mouse and keyboard too), and restart.
Still have blue screen? = no, add devices one at at time to identify problem child, = yes, then hold power button till shutdown, reconnect mouse and keyboard only (no networking needed for this). Follow on-screen prompts or user manual to enter system BIOS settings and reset to factory defaults and reboot.
Still have blue screen? = no, you're fixed, = yes, does system have embedded diagnostics? If so, run surface scan on hard drive, automatically repair any bad sectors, if it finds any then boot and see if you are fixed. If it doesn't find any problems with the drive then you either have bad/corrupt drivers installed, or a piece of failing hardware beyond this type of troubleshooting. Also run diags on memory if provided.
If you don't have embedded diags then you are going to need to boot from an alternate source (CD or USB) and run diags from there. Here is a link to a page that walks you through creating one (from a working computer obviously) https://www.makeuseof.com/tag/the-ultimate-pc-repair-toolkit-in-your-pocket-ultimate-boot-cd-on-a-usb-stick/. Good luck!
who's built in HP
or HP, external
or other computer (NON STATED)
nor what OS you run?
if the camera is HP and PC HP , HP.com has driverss if not 20 years old.
is it? no camera or PC stated at all. maker/model.
HP Computers &... | Answered on May 11, 2019
Try to burning other dvd's from your disk. Install Nero or Raxio creator software for burning dvd's. If this is your dvd drive problem, discuss this to your dealer.
HP Computers &... | Answered on May 08, 2019
HP 2x1x16 Kvm Ip Switch 16 Port 410530-001 408965-001 Logo
0 questions posted
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
install windows 7 pro
  • Computers & Internet
