20 Most Recent HP VECTRA VLI8 P3 Motherboard (KZM6120) Questions & Answers
Hi RobPu,
I have searched everywhere. I even entered a chat windows with Compaq & asked for a site to download the manual for Compaq Presario SR5015LA Desktop PC which has the motherboard MCP61PM-HM in it. (Nothing). This board was made by
ECS known as EliteGroup. Still nothing. Forms for the most part do not help, only with drivers. Drivers for the board can be found on Compaq's web site.
http://h10025.www1.hp.com/ewfrf/wc/prodinfoCategory?lc=en&cc=us&dlc=en&product=3411762
But the manual will not download. That's what is needed to hook up the front panel pins to you're case. I even looked for other possible boards who's layout was close to the MCP61PM-HM.
Nothing! I did find other Compaq PC's that also had the same board in it but after looking through the manuals, not one actuallys shows where to plug the front panel LED's on to the board. Why? Because Compaq does not support a user changing out their case for another. There is no money in that.
For the most part RobPu, system boards share some things in common. I am posting a picture for you. This pic is upside down for you so try & work with me here. Hook up you're LED's as shown. This should work for you. Pin 1 is you're starting point.
daa3370.jpg This is standard for ECS boards even if it's being sold by Compaq. Like I mentioned, for you it is posted unside down.
Try it, I'm sure it will work for you.
Enjoy!
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
HP VECTRA VLI8... | Answered on Feb 26, 2013
The old card has to be disabled in bios or some times you can do it from safe mode by uninstall. For bios settings depending on the PC it self you would have to start the pc and first screen that shows up will tell you how to access bios settings. In the settings there is an option to turn off on board video card. Hope this helps.
HP VECTRA VLI8... | Answered on Mar 04, 2011
Your system doesn't support USB 2.0, only USB 1.1 . To have USB 2.0 you will need to add a USB 2.0 card to your system..
HP VECTRA VLI8... | Answered on Feb 09, 2011
Use your Microsoft word installation CD/DVD.
Or you can download the free OpenOffice alternative here:
http://www.openoffice.org/
HP VECTRA VLI8... | Answered on Jul 20, 2010
diagram at HP support forum sows board and labels for connectors.
http://h30434.www3.hp.com/psg/board/message?board.id=HardwareDPC&message.id=87&query.id=879674
HP VECTRA VLI8... | Answered on Mar 16, 2010
I'm assuming you didn't use the Cmos jumpers to reset the cmos and only replaced the battery?
Checked board to see if there are any capacitors bulging, leaking r blowing?
You don't say why you removed it in the 1st place? I'd remove it again and test it outside the casing, see if that solves the problem, then look inside the casing to see if there is anything that could be causing a short,
Other than that, you may have damaged a component on the board when you originally removed it
HP VECTRA VLI8... | Answered on Feb 11, 2010
hi sounds to me like either the air flow metre or the cam sensor at fault but your better of getting the car pugged into a diagnostic machine which will tel you straight away whats at fault. regards
HP VECTRA VLI8... | Answered on Feb 01, 2010
upgrading your bios, changing rom or using another bootable disc can solve the problem
This is usually a sign the the hard drive is start to fail. It will just get worse until the drive completely dies. Back up your data now and plan on getting a new hard drive ASAP. If you get the new drive before the old on fails there are tools that will allow you to copy your old drive to the new drive, this way you loose nothing and are up an running in the shortest time.
HP VECTRA VLI8... | Answered on Jan 22, 2010
+5v Out Ground
The one all by its self is the 5 volt
the one in the middle is SPDIF Out
the one next to this is ground
HP VECTRA VLI8... | Answered on Jan 16, 2010
necesito el driver de esta placa madre
HP VECTRA VLI8... | Answered on Dec 16, 2009
Computers & Internet Logo
52 questions posted
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
hp mcp61pm hm motherboard diagram
  • Computers & Internet
