20 Most Recent SmartDisk FireLite 40 GB Hard Drive Questions & Answers
Try rebooting your computer with the Smart Disk plugged in. You can also try moving all the contents of the Smart disk to your computer and access from there.
SmartDisk... | Answered on Aug 14, 2015
I can recover your info call or leave a comment on where to reach you.
SmartDisk... | Answered on May 02, 2014
Input voltage for the FWFL40 is 33V DC. I hope this helps
SmartDisk... | Answered on Nov 04, 2013
Either the hard disk has become corrupt or the OS that was installed is not being recognised now. Try making it slave or secondary and see if the pc is able to detect it then recover the data that you want to save else format it.
SmartDisk... | Answered on Oct 21, 2013
If you are reformatting the disk on a Mac, then open the Disk Utility, then click reformat, and choose the format FAT32. If you have it connected to your PC, go to my computer, right click and select reformat, then choose FAT32.
DISCLAIMER: REFORMATTING AND/OR FORMATTING WILL ERASE EVERYTHING THAT IS ON THE HARD DRIVE. MAKE SURE YOU HAVE EVERYTHING YOU WANT BACKED UP.
Hope this helps!
SmartDisk... | Answered on Oct 13, 2013
You will need to recover the data using something like this data recovery program.
http://www.asoftech.com/adr/
I've had to use it many times in the past but in this case you need to take out the hard drive from mac and put it into a Windows computer as an external drive or slave drive and run the software from there. It will rebuild the drive and hopefully recover the files.
Good luck.
SmartDisk... | Answered on Dec 05, 2012
This could be an issue where the part of the hard drive you are trying to access is corrupt and not accessible which would explain the reason that it would let you access the other partition.
Now I have seen cases where Malware can break the link of a Hard Drive.
So let's try a couple of steps.
Let's go back in to "Disk Management"
Lets right click on the partition that you are not able to access and select "Change Drive Letter and Paths"
Now try selecting a new Drive Letter.
This will restore the path if it has been broken.
There are also Data Recovery programs that might be very helpful to recover your important information.
Downloads to Recover Your Files and Save Your Bacon and 10 Best Free Hard Drive Utilities.
Some addition links found on Google
http://www.datarecoveryreview.net/
http://www.easeus.com/resource/hard-disk-data-recovery.htm
hope this helps
SmartDisk... | Answered on Oct 05, 2012
I have a firelite USBFLB60 60gb. My cord broke, so I just ordered "Cable Wholesale USB Type A Male / Mini-B Male Cable, 5 Pin, Black, 1 ft" from Amazon for very cheap. I think that is the correct adapter, and I imagine it would be the same for yours.
SmartDisk... | Answered on Aug 04, 2012
I found drivers at this URL: http://www.xpdrivers.com/usb/smartdisk/_3_2585.cfm
You should go there and be able to find what you need for the 64-bit Vista OS.
Good luck,
-a.
SmartDisk... | Answered on May 28, 2012
SmartDisk FireLite 40 GB Hard Drive Logo
120 questions posted
Top SmartDisk Computers & Internet Experts
Jeffrey Groves
Jeffrey Groves
Duncan Mutch
Kris
Are you a SmartDisk Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
FireLite SmartDisk
  • FireLite SmartDisk
Most Popular Question
smartdisk firelite 40 gb hard drive
  • Computers & Internet
