This indicates that the fuser req' replacement but it can also be
a mpcb fault.
If the problem occured during a flash storm i would go for the
mpcb.
mongrelken.
I have a Brother HL-5240. Same problem (all LEDs flashing) due to same cause (hail storm/power failure). The 8-step procedure above worked perfectly for me and printer now fixed!! Only difference was that step 7 doesn't apply (red LED did not light), but fixed all the same. Thanks!!
If everything at the printer looks fine (test prints, and no errors on the display) I would de-install and reinstall the software. The DE-install is important, DO NOT just reinstall over the top of the current installation. Also I would reboot after I removed the software and BEFORE I reinstall it. It might be overkill but it won't hurt to be through.
THIS worked: (from another complaint posted March 19)
found this solution for a 2030 printer. haven't tried it yet but its a suggestion.
had the same problem and Brother tech support walked me through this procedure which worked fine..
1. Power Unit off
2. Open front cover
3. Press and hold GO and turn power on
4. When all 3 lights lit release and press GO twice
5. All lights turn solid
6. With all solid, press GO 5 times
7. Ready light GOes red
8. Close door and you're all set
