SOURCE: Hi there , my canon MP630 has all of a sudden 6c10 error ?
That error says that either something is jammed in the purge assembly, the unit on the right that cleans the printhead, or the purge assembly is stuck or broken. If you unplug the printer with the carriage in the center you can use a flashlight to inspect the area on the far right where the printhead parks.
SOURCE: My Canon MP630 has a 6C10 error
You have a "Valve Cam sensor error". Usually caused by paper debris inside the printer, probably near the purge unit.
Have a ggod look inside and see if you can see any bits of paper.
SOURCE: MP560 Canon Printer Error 6C10
The above suggestion worked short term, but in about a couple of hours, I'd get the same old error code again. Finally, I found a solution that worked for my MX860 on fixya.com written by "pineworks". The link is as follows: http://www.fixya.com/support/t4097826-aborber_full_error_message
Don't know if you've found an answer to this problem yet, but I had the same issue for about three months. Finally, I found a solution that worked for my MX860 on fixya.com written by "pineworks". The link is as follows: http://www.fixya.com/support/t4097826-aborber_full_error_message
For months, I've had to power off, disconnect from computer, and power on again to kick-start the printing. It was driving me crazy. So far, "pineworks" solution has been a permanent one. Been about a week and have had no problems yet.
SOURCE: Canon iP4700 with error 6C10
after youll be sure that you have communication with your internet modem ! delete your printer from your computer and install it again. at list thats what i did with my mp640 on my mac book. system preferences/print + fax. i suppose its something similar with the pc. i solve my problem this way. hope i help.
SOURCE: Canon PIXMA IP3600 Service error 6C10, and doesnn't print at all
Try keeping the paper only in the bottom tray (there's a tray in the bottom) Try pulling any paper out of the top and just close that top tray. Open up the head so that u can see the ink cartridges and turn the printer on and off and maybe it will center itself again. If it's still not working (even if lights aren't red and print head wont align in the center) try manually moving the head back and forth like 18 times so you can lubricate that rail in the back that's holding it. After that, re-turn it off and on again.
It is my pleasure to guide you.
I have done some extensive research on your 'error 6C10'.
I have looked at the following:
QUOTE
PIXMA MP500 Printer
Canon Pixma MP500 Service Manual
http://www.printermanualguide.com/canon-printer/canon-pixma-mp500-service-manual.html
2-2. Service Call Errors (by Cyclic Blinking in Orange (Alarm LED) and Green (ON/OFF button), or Alarm LED Lit in Orange)
Cycles of blinking in orange (Alarm LED) and green (ON/OFF button) 16 times
Error [Error code] Valve sensor error [6C00]
Conditions An error occurred in the valve sensor during cleaning.
Solution(Replacement of listed parts, which are likely to be faulty) - Logic board ***'y (QM2-3078)
UNQUOTE
I realize that the '6C00' error is not exactly your but the manual does not have the 6C10. You can download that at the above link.
I also look at the http://www.retrevo.com/support/Canon-MP500-Multifunction-Printers-manual/id/259bh640/t/2/ Canon Pixma MP500 Users Guide Manual. There are several codes but not the 6C10. You can download this above as well.
Good luck and please post back that you are successful, giving thumbs up, or if I can be more helpful.
