20 Most Recent Canon PIXMA MP980 All-In-One InkJet Printer Questions & Answers
Can I remove without printer on?
Canon PIXMA... | Answered on Feb 17, 2019
https://consultancomputeraplus.blogspot.com/2017/09/reset-canon-mp980-mp988.html
Canon PIXMA... | Answered on Jan 12, 2019
I think the printer is defective and based on cost of repair versus replace make a decision.
Canon PIXMA... | Answered on Mar 17, 2017
Error 6500 is a logic board error code (= 'other hardware error').
Before committing to replacing a logic board, ensure that the error has not been generated and held by spurious external signals. Reseat the ink cartridges. Remove any memory card(s). Check any flaps / covers are properly closed (eg. CD printing cover). Turn off the printer and disconnect the power lead and USB lead to the computer. Leave the printer disconnected from power and data signals for several minutes, allowing time for any static electrical signals present on the logic board to discharge.
Reconnect printer and test.
Canon PIXMA... | Answered on Nov 05, 2015
The scanner lock on the MP980 is on left hand side of the scanner unit. It's closer to the hinge of the document cover and almost centered between the scanner glass and the edge of the printer. If you lifted the entire scanner unit, you won't see the switch. You should be able to push the switch towards the open lock symbol with your finger or thumb. The Getting Started guide has a pretty good picture of where the switch is in Step One. The guide is available on the product page, http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp980#BrochuresAndManuals , in the Brochures & Manuals section. The current link to the Getting Started Guide is http://gdlp01.c-wss.com/gds/2/0300001552/01/MP980_GS_EN-US_V3.pdf . After moving the switch, turn off the all-in-one. Then unplug the power cord to clear the error message from the printer's memory. After a few minutes, plug the power cord back in and turn on the printer.
If the error persists and the scanner is unlocked, the scanner mechanism may be damaged. If that's the case, your MP980 needs service. If the unit is under warranty, contact Canon. (If it isn't under warranty, you'll need to decide if the unit is worth the shipping and handling fees and the minimum $50 or so charge just to determine the problem at a service center. (That fee will be applied to the cost of fixing the printer, if you decide to have the technician continue to work on the unit.)
I hope this helps.
Canon PIXMA... | Answered on Sep 22, 2015
Under the lid on the left hand side..Look for a lock and unlock symbol.
Canon PIXMA... | Answered on Sep 21, 2015
Canon PIXMA MP980 All-In-One InkJet Printer Logo
133 questions posted
Clive
Clive
old marine
old marine
View Most Popular
PIXMA Canon
  • PIXMA Canon
Most Popular Question
canon mp 980 won 39 t even copy or scan
  • Office Equipment & Supplies
