Question about Canon PIXMA iP3600 Photo Printer
6C10 error (valve cam sensor error) is a mechanical problem in the purge unit area where the valve cam sensor is located (on the purge unit just behind the power switch button). On my experience, the movable gear assembly (with spring on top) can't move downward to move the other gear that is connected to the valve cam therefore the sensor is not sensing any movements.
Solution:
1. Open the entire top cover.
2. Locate the purge unit (the area where the ink carriage rests when not in use).
3. Move the carriage to the middle of the printer to access the purge unit.
4. Try to gently move the gear assembly downward using your finger or a screw driver to loosen the stuck gear.
5. Turn on the printer to test.
Posted on Jul 16, 2012
I have a Plymouth G V van my hazard flasher and turn signal is not working I change all the fuses and relay box under the hood and under the dash board.
Posted on Jul 05, 2014
SOURCE: I have a Cannon PRIXMA MP130. I lost the software
http://software.canon-europe.com/products/0010171.asp
Win 95 driver above.
Posted on Apr 19, 2010
SOURCE: Canon PIXMA IP3600 Service error 6C10, and doesnn't print at all
Try keeping the paper only in the bottom tray (there's a tray in the bottom) Try pulling any paper out of the top and just close that top tray. Open up the head so that u can see the ink cartridges and turn the printer on and off and maybe it will center itself again. If it's still not working (even if lights aren't red and print head wont align in the center) try manually moving the head back and forth like 18 times so you can lubricate that rail in the back that's holding it. After that, re-turn it off and on again.
Posted on Aug 02, 2010
Oct 26, 2015 | Computers & Internet
Jul 19, 2014 | Cannon Office Equipment & Supplies
Apr 21, 2014 | Canon PIXMA iP3600 Photo Printer
Dec 17, 2012 | Canon Pixma MP620 All-in-One InkJet...
Jul 04, 2012 | Canon MP640 All-In-One InkJet Printer
Apr 29, 2017 | Canon MP560 All-In-One InkJet Printer
Jul 14, 2011 | Computers & Internet
May 12, 2011 | Canon MP640 All-In-One InkJet Printer
Jun 30, 2010 | Canon Pixma MP500 All-In-One InkJet...
Sep 27, 2009 | Canon PIXMA iP3600 Photo Printer
980 people viewed this question
