SOURCE: Maytag Epic
the control board has loose solder connections around the relays.
see this
diff model same issue with new boards as they make them all.
http://www.fixya.com/support/t364216-whirlpool_duet_ht_ghw9400pl0
being it is in warranty its too early for you to fix it yourself.
you will have to wait for them to come out and say the parts are on backorder.
SOURCE: load off balance error dc. Wont rinse or spin
Hello nikimiguel,
I’m an Owner like you I own the FAV6800AW and have helped many folks on this and other forums with this issue.
You are experiencing a classic malfunction of the One-Way Roller clutch bearings in the Clutch Pulley assembly. It sounds like you are in the early stages of the issue. I have put together a step by step maintenance process to clean up and re-lube the One-Way Roller clutches in the Clutch Pulley assembly see this post Clutch Fix Post for what’s involved. Look on the right top back of your Console. If you can give me the first two numbers of your serial number i.e. 10, 11,12, tru 17. That will let me know if your machine will use an Upper One-Way Roller clutch bearing ring. Mechanical skill sets to perform Clutch maintenance or replacement are basic, anyone can do this it’s just a tight work area. Your option is to DIY or call in a repair service. I would ballpark the repair cost at around $300 if they know what is wrong and how to fix. DIY the fix it and you may need a a can of WD-40 and Slick 59 One Lube cost around $10 if the One-Way Roller just need to be cleaned up and re-lubed. If the Clutch pulley needs to be replaced I will show you a site where you can purchase for around $60 delivered to the house.
See this most recent post of a forum member who is back in service with my process.
Standing by if I can help….Rich aka dh1200s
SOURCE: OUt of balance during rinse and spin cycles
I have the same problem. During the spin cycle, the washer spins all over the room.....very loudly.
SOURCE: maytag epic z out balance repair man came and said
he's telling fibs! there not that way at all,,,,
did he look inside at the shocker springs? if one is missing becouse its broken off ,,,the washer learn's to dance about!
get him back for a proper fix and not a con job!
SOURCE: During rinse cycle my Maytag neptune washer stops
The LR error on your non-spinning Maytag Neptune is usually, though not always, accompanied either by a burn spot or a blown fuse on the Motor Control Board.
Maytag upgraded the motor and motor control board because this problem was so prevalent. Big rash of these a few years back... and insludes replacement instructions with the kit.
The LR code means "locked rotor" which is just a way of saying the control is not seeing the motor turning.
The image below contains the wiring diagram for this washer as you requested but there are some other things to consider.
Usually when the LR code is displayed the motor has stopped turning for some reason.
By definition the LR code means the control has tried to turn the motor but was unable to.
The error code can be caused by to large of load, to much soap/suds in the water or a problem with the spin bearing.
The cause of the LR message can be little problem like suds or a major problem like the spin bearing and sometimes it's difficult to pin down.
You don't mention in your question if the LR code occurs every load or once a week.
Try running a rinse and spin cycle empty and see if the washer completes the cycle.
The 2nd image contains the information on how to enter and run a diagnostic cycle which may help pin the source of the problem down.
This test completes all functions of the washer is a short time. It will fill, tumble, drain and spin all is a few minutes.
At the end of a successful test cycle a PA should display which means "Passed" and is what you want to see.
Image 1: http://media.fotki.com/1_p,sqwrrqkkqkstsftxgtqsskgwtqkq,vi/kkwrfdskkxkgbffwfww/1/1303472/5961857/image53872img-or.gif
Image 2:http://media.fotki.com/1_p,sqwtrsgdwsqtqsqxgtqsskgwtqkq,vi/kkwrfdskkxkktggsfsw/1/1303472/5961857/image53908img-or.gif
From another source..."Installing replacement motor, motor control harness, and motor control circut board.
Pretty easy install. On a scale of 1 to 10 (ten being hardest) I'd call it a 3.5. If you can use a screwdriver, a wrench, and have played with legos before, you can probably do this job. It took me about 3 hours to do, but this was with inferior tools, and two smoke breaks included.
Minimum tool requirements: Adjustable-head cresent wrench (8 or smaller handle), phillips head screwdriver, utility knife.
Recommended tool equirements: Small ratchet with socket set, ratcheting screwdriver with phillips head and small socket attachments, brew.
The instructions are pretty clear. Once you pull the front panel off, there are two braces at 45 degree angles on the lower corners of the washer. The instructions don't ask you to, but I would remove the brace on the left to make life easier. This gives your arm more room to work and makes it easier to pull the motor out the front.
They ask you to remove the wiring harness from the motor first and then pull the harness out with the control board. My wrench was too big to get to the bolt to remove the harness from the motor. All I did was cut the harness - since they supply a new one - then pull out the control board, then pull out the motor. As far as getting the pulley off, slip it on and off at the large wheel, this is much easier than taking it off at the small motor drive shaft. The only other thing of note is to make sure you look at the diagram for the conectors a few times before you snap it together. There are a few ways you could hook it up wrong so pay attention. There should be no loose ends when you finish. Also, I couldn't get the flange back on on the rear acess panel when closing it up, but it doesnt seem to serve muc purpose besides asthetics, so I tossed it.
The $200 for the parts and shipping was well worth it. I saved about $150-250 to do it myself...."
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question(*&^%
