The temperature varies according to the use if you just pure out hot water for fist time should be around 90 degrees however after one or two mugs can go up to 75 to 80. The same is for coffee. In any case the 70 degrees is low. Please note that I mention the temp. at exit point not in the cup since some seconds after the exctraction is normal to go at 70.
Hello - Hot water is most often 10 degrees colder when it arrives at your machine from when it leaves your hot water heater. In general hot water is 130 degrees Fahrenheit (54.4 Celsius) or above. Warm water is between 110 and 90 degrees Fahrenheit ( 43.3-32.2 Celsius). Cold water is generally between 80 and 60 degrees Fahrenheit (26.7-15 Celsius). If cold water is below 60 degrees Fahrenheit (15 Celsius), clothes are unlikely to be cleaned very well. After confirming information and it proves to be ineffective contact a professional to move forward accurately. Unit could possibly be experiencing a defective timer, temperature sensor, or water valve.
