SOURCE: blows cold air
Sounds like you have a problem upon start up of heat. Your safteys maybe shutting you down, and restting voltage to your curcuit board allows you to have another heating cycle. Honestly you may due justice calling a tech.
SOURCE: home central air conditioning unit
check the filter, make sure it's not plugged. Make sure all the vents are open. Are the lines freezing up (have ice on them?) Could be a lot of things but if it is not blowing much air then you may have a motor problem or dirty filter. If the unit is freezing up then probably have a leak and will need to be found, fixed and recharged.
SOURCE: Blueway split system wall air conditioning doesn't work properly.
Hi,I have had problems with my Blueway A/C it was very cheap but NASTY,anyway I might be able to help, I made a website with my manual that includes the error codes that I could not find on the net anywhere ,I have also sourced a company in sydney who has spares and have the contact details listed and started a forum that we can help each other out with
SOURCE: Air-conditioning not icy cold inside my VW Passat TDI 1996
chances are if you system was serviced by modern equipment then they would have pulled a vacuum before recharging .. that would eliminate moisture in the system .. the evaporator is inside your heater box .. you cant see it .. the condenser is the radiator like device in front of your engine cooling radiator ..
if the system is changed properly and still does not work or works intermittantly . then there is a good chance that the air conditioner clutch electronic module is bad .. thats a relay like device located on the drivers side behind the dash .. you have to snap off the dash side panel .. its normally hidden by the door .. inside that is the fuse panel and behind that is the relays/electronic modules .. the one that operates the air conditioner clutch is marked 384 .. there are other possibilities depending on your a more precise description of the problem ..
