Below are instructions that I have found from the internet. Hope that they will help.
Open the front cover of the printer.
Hold down the Go button for 4 seconds until all the LEDs light up. Then release the Go button
Remove the drum unit and toner cartridge assembly.
Replace the drum unit and toner cartridge assembly back into the printer.
Close the front cover of the printer
Your drum unit should now be reset
MFC / DCP PRINTER SERIES
1.Remove the drum unit and toner cartridge. Wait 1 or 2 minutes.
2.Replace the drum unit and toner cartridge into printer.
3.The error message "Change Drum Soon/Drum end soon" will continue to appear if the drum counter was not reset when you replace the drum unit.
4.To clear this error message, you need to reset the drum counter as instructed below.
5.Make sure that the machine is turned on.
For MFC users: To confirm you are installing a new drum, press 1. For DCP users To confirm you are installing a new drum, press the Up Arrow key
7.When the LCD shows Accepted, close the front cover.
8.Your drum is now reset.
Resetting the drum unit will not improve print quality. It only resets your drum and allows you to continue to print. You decide when to replace the drum unit not the manufacturer!
Time to really order a new drum and really replace with a new one.
6.Press Options.
I have a Xerox 4250. After the ink cartridge ran out I replaced it with a new one and got the "replace photoreceptor cartridge" message. Reinserted the cartridge and it stayed. Called Xerox and they couldn't explain. I turned the machine off and on and the message changed to "replace photoreceptor cartridge" but an additional message of replace Smart Drum came up. I replaced the Smart Drum and it is working fine now. Note: I really don't think it was time to replace the Smart Drum. But the nearest authorized service provider was 3.5 hours away and this had to be cheaper than a service call from that distance.
You can order a crum chip or replace the cartridge.
Google a business called The Parts Drop. Call and ask for Britt. I am sure he will have the crum chip to replace and reset that code fairly cheeply.
Your Xerox has two cartridges - one is the drum cartridge and the other is a toner cartridge. Please check the following I've researched from your user guide:
Replacing the Drum Cartridge
The drum cartridge is a customer replaceable unit. After approximately 55,000 copies/
prints, the machine will display a warning message before the drum reaches the end of
life. Order a replacement cartridge now to insure continuous operation.
Country Part Number for the drum cartridge replacement All countries 13R589
Removing the Old Drum Cartridge 1. Pull the front cover towards you to open it. 2. Open Tray 5 (bypass tray) if necessary, and then open Cover A while lifting up
the release lever. 3. Lift up the colored lever, and slide the drum cartridge out until you can lift the
handle on top of the cartridge. 4. Hold the handle and remove the cartridge from the machine. NOTE: When replacing the drum cartridge, make sure that the new cartridge is the
correct one specified for the machine.
Recycling the Drum Cartridge
The drum cartridge is designed to be re-manufactured. To recycle used drum
cartridges, return them to Xerox in the original packaging. Return labels are included
with each new cartridge.
Inserting the New Drum Cartridge 1. Remove the new drum cartridge from the box. 2. Undo the sealing tape and carefully pull out in the direction of the arrow to
remove the black protective sheet from the cartridge. 3. Place the cartridge in position and, using the handle, slide it into the
machine until it clicks. 4. Pull out the cartridge tape completely without breaking it. 5. Push the cartridge again so that it is correctly placed. 6. Close Cover A until it latches and then close Tray 5 (bypass tray). 7. Close the front cover.
I HAD the same problem...a couple of posts up/down, someone suggest to re-align the film roll on the Drum. This worked for me. There are two wheels on the outer-side of the film reel (the film reel is one of two reels on the main top drum). Take out the drum, not the green reel, but the other one. Check both ends and you can se/feel two little silver metal wheels (again, at the ends). Roll the film around with your fingers until it is aligned evenly with the wheels. The metal on the wheels should not be showing at all, they should both be covered by the film reel. Replace the drum and cross your fingers. This worked for me...I'm sure a NEW drum would fix the problem, as well.
