20 Most Recent OKI C5150n Led Printer Questions & Answers
If the paper under the crease has print and the fold is "glued down", it is most likely to be a problem with the fuser. Try removing it and look for evidence of warping in the pressure roller. If the fuser looks clean and tidy, go to the other end at check over the paper tray and paper feed mechanisim. It is possible the paper is catching on something at the start of the process. This is most likely if there is print over the crease but not under the fold.
OKI C5150n Led... | Answered on Feb 13, 2018
Where your network cable plugs into the printer there should be a green led on and possibly an orange one flashing (Shows data passing thru). If neither are lit then try another network cable (may be stretched). If still nothing then just try another network port. if still nothing then yes the network port which is part of the main board will be U.S. and new main board will be required. maybe expensive.....
OKI C5150n Led... | Answered on Aug 07, 2017
What you need to do is power off the machine. Open the top cover and look at the Magenta LED print head. At the right end there is a white flat ribbon cable plugged into it. Pull out the cable and let it dangle BEHIND the print head. Close the cover and power up. You will hear no motors and eventually you will get a fatal error 13x. Power OFF and push the cable back into the head after wiping the back of it with your fingers. Be careful and make sure it goes in straight. If happy and it looks like the other three then power up again. You should hear the motors once again and all should be well. If you still hear nothing then turn off immediately and follow the instructions again. If you get it wrong then you may have shorted out the control board which renders the machine useless. You do this at your own peril. It usually cures all its problems. good luck
OKI C5150n Led... | Answered on Mar 31, 2017
That is a fuser erron code. Abnormal temperature. You will need to replace the fuser. Sometimes I have sen a buildup of toner on the thermistor. If you can get to it. You can try to clean the toner off. Be careful. Very hot.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
OKI C5150n Led... | Answered on Sep 28, 2016
remove toner and drum unit
remove toner
check to see if there is toner in the drum unit if not fill unit run 5-10 prints
replace dev roller
replace drum cylinder(opc)
OKI C5150n Led... | Answered on Oct 27, 2015
This printer is not capable of "Full Bleed" printing.
You can change your margins in your software to all zeros or narrow to get the maximum print area.
OKI C5150n Led... | Answered on Nov 25, 2014
Either old TV is capable of using an unboosted signal and the new not, or there's further setup of the inputs required.
OKI C5150n Led... | Answered on May 10, 2014
  • From: Michael ([email protected]).)Get the book: "Easy Laser Printer Maintenance and Repair by Stephen J. Bigelow".
    Your local library should have it or be able to get it. Stephen J. Bigelow has several other books on printer repair, both laser and non laser types. All are very good.
    Warnings about vacuuming laser printer toner before using a household vacuum cleaner to do this!
    Printer/Copier/Fax Repair FAQ Table of Contents.
    Dot Matrix and Daisy-Wheel Printers
    So you took your printer apart....
  • OKI C5150n Led... | Answered on Sep 13, 2013
    Have you cleaned the print heads?
    OKI C5150n Led... | Answered on Apr 18, 2013
    OKI C5150n Led Printer Logo
    131 questions posted
    Popular Products
    Top OKI Office Equipment & Supplies Experts
    Steve Allison
    Steve Allison
    WTF Chuck.....
    WTF Chuck.....
    Clive
    Clive
    Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
    View Most Popular
    C OKI
    • C OKI
    Most Popular Question
    received message 543
    • Office Equipment & Supplies
