There are several recovery softwares available, but none of them can gaurantee the file to be recovered 100%. you can google for "File Recovery softwares". many will give you the option of a trial version.
OK! That often depends on what have you've
done to this hard drive after the formatting process.
In fact, nowadays, the deleted files on a
hard drive are not actually destroyed immediately after the formatting process.
They are still there and become invisible. So, act carefully to get these
deleted files back:
1. Stop using this hard drive before you
are ready to restore your inaccessible files.
2. Plunge this hard drive to your computer.
3. Download a formatted hard drive data recovery freeware to retrieve all your
lost files back.
This professional data recovery freeware
has helped many people around me restore their inaccessible data off from a
phone/camera memory card or hard drive. It could be a good choice for you to go
on.
Try to read more detailed information of
this camera data recovery freeware here:
http://www.freeware-fix.blogspot.com/2013/02/hard-drive-format-recovery.html
4. Do not save or back up all the restored
data on the same hard drive in case of any data recovery failure.
Next time, you should always be careful to
your important data and remember to back it up well in case of similar data
recovery problems.
SOURCE: I had format my Fs-4 Pro HD, and I need that
Hello
My
apologies if this message finds you long after posting this problem ,
but I am currently working through a backlog of problems that never got
answered and hopefully this info can still be of use if not now possibly
in future.
Please download Disc Digger HERE.
This is a free tool you can use that works very well and there is no
installation required, just run the program once you downloaded it.
Once
you have connected the memory disk / hdd to the computer , run the program.
On
the program , select the dig deep option for accidentally deleted files
or dig deeper for a formatted drive. Then select the disk you want to do
the recovery on and run the program.
The data will be displayed
and you can recover it from there. This will only work if the card has
not been used since the data was lost. Save the files to a location
on the computer hard drive and not back to the disk it is recovering from as this will
overwrite the other pictures that still needs to be recovered.
Some of the properties of the files may become lost in the recovery but the pictures should be fine.
You will also only be able to recover certain file types using this method.
Feel free to ask if you need more assistance.
Kind Regards
Andrea
OK! Be relaxed! Nowadays, the formatting
process will not actually erase everything contained on a hard drive
immediately as we think. The deleted files are still there and become
invisible. So, just act carefully to get these contained files back:
1. Stop using this hard drive right now in
case that any new file on it may overwrite your wanted files.
3. Download a hard drive data recovery freeware to retrieve all your lost files
back.
In fact, there are plenty of drive data
recovery programs available online. But, not all of them can work as
efficiently as you think. So, you should pay attention to select a proper one
for your data.
If you still have no idea, you can firstly
try a drive data recovery freeware online that can work much more efficiently
than some paid ones:
http://www.freeware-fix.blogspot.com/2013/02/external-hard-disk-format-recovery.html
4. Save or back up all the restored data on
another drive in case of any data loss.
Next time, you should be much more careful
about your data and always back up everything important well.
