Vacuums Logo
Posted on Feb 28, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a bissell 7.5poweramp uprite vacuum with a broken belt for the brush. What size belt would i need to fix this?
A
Anonymous
I have a galexey 3507a500 and my belt broke and i can't find a replacement belt at any store where do i get a replacement belt for a 5275 belt.
Anonymous
Level 3:
President:
  • Master 1,673 Answers
  • Posted on Feb 28, 2008
Anonymous
Master
Level 3:
President:
Answers
1673
Questions
Helped
704582
Points
3439
Not sure with having the model number, there may be a number on the belt, like style 7 etc. If no number, get me the model number and I can find out.
The turbobrush for my cleanview helix 22c1 is not working
It's probably either just dirty, or the belt is broken. If it's dirty, you can just take the cover off (two Phillips head screws on the bottom) and clean everything off the brush.
If the belt is broken, you can tell by turning the large gear at the back of the brush -- if the brush turns when you spin the gear, the belt isn't broken -- then you'll need to replace it. You can buy a new belt online, or you can buy a replacement Turbo Brush directly from Bissell ($24.99).
Hope that helps!
3answers
We have power but the front brush does not turn?
Your belt is probably broken, stretched or worn. You can get a replacement belt here:
Bissell Healthy Home Replacement Belt
4answers
Brush heads won't spin
Your belt is stretched, worn or broken and therefore not turning the brush. Here is a link for the replacement belts you need and the manual which has instructions:
Bissell PowerForce Replacement Belts
Bissell ProHeat, Brush won't turn, belt fine.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
dh
12helpful
Brushes won't turn and vacuum will not pick up sprayed cleaner
There's a Capt. Obvious fix to check before you go any farther. Like many vacuum cleaners, the brushes on the Bissell carpet cleaners, by design, only spin when the handle is not locked in the upright position, so be sure to plug it in, turn it on, and depress the foot pedal to lower the handle while watching the brushes one more time to be sure that the fix isn't that easy.
If the brushes still won't spin with the handle in the unlocked position, lift the handle back up into the locked position, power off and unplug the Bissell, and look down and see if either of the two belts that make the brushes spin are broken, as a broken belt, or a belt that's come off the track, is the next most likely problem. Both belts must be unbroken and in the right place for the roller brushes to spin.
These belts can be seen in the clear plastic pieces on either end of the roller brushes. If you're having trouble locating them, **with the Bissell unplugged so the brushes won't suddenly start spinning and hurt your hand**, try spinning the brushes with your fingers while watching for the belts. They're black, about the thickness of two quarters, and the bigger one of the two (on the left end of the roller brushes, as you face the front of the Bissell), is just big enough to fit around both roller brushes. The smaller belt, goes around the back roller brush on the right and to a smaller cog wheel behind it. If you see a broken belt, or a belt off the track, that's your problem.
Here's a video you can watch for free on Bissell's website that tells how to replace a belt. I'm sure the belts can be ordered online somewhere or found at some Bissell dealers or repair shops. Note, again, the two belts are different. If only one is broken, be sure to order the correct one.
http://cache.vendaria.com/vpop/VpopV6.html?ct=13&ctname=CT630X556D630X390&fw=630&fh=556&logo=49&fv=10&ap=vnd_bissell_change_belt_proheat_2x&purl=MAIN_bissell_change_belt_proheat_2x&iid=sbpgzLIuvIlJlJquLvumgwqKqvIqvv&bg=ffffff&nm=BZOpener&curl=&err=0&title=Bissell&tp
If the belts are intact and in the right place, does the metal cog wheel behind the roller brush right turn when the Bissell is on and the handle is dropped? If not, then the motor that turns that cog wheel must be burned out.
2answers
Brushes do not turn
You should see if the brush belt is broken. I broke mine you can find the part at walmart or on bissell.com
2answers
My power brushes on my bissel carpet cleaner stopped working. They do not rotate. This is the 2nd power cleaner I have bought and it has the same problem as the first one. What is the problem with the...
Brush belt is very weak.
Brush Belt broken or disconnected. Very weak belt. Colossal engineering mistake by Bissell. Belt itself and its components are under way to much stress for the size they developed to perform their task. For Quality Control to let such an obvious blunder pass can only mean that it was intentional for reasons, Im sure, beneficial to Bissell and costly for the consumer. No telling how many people buy another entire machine when this rubberband of a belt breaks like it was intended. Bissell is not a consideration of myself or anyone I can enlighten.
2helpful
Bissell 37602 roller stopped spinning
If the roller brush as stopped spinneng .and the brush motor still works the brush belt as broken,
you must replace the brush belt, t
Top Vacuums Experts
AskDyson
AskDyson
Anonymous
Are you a Vacuum Expert? Answer questions, earn points and help others
