Tip & How-To about Vacuums
Bissell Proheat Upright Wet/Dry Vacuum Problems
There are many questions about the Bissel Proheat Upright Wet/Dry Vacuum cleaners.
It seems that there are many questions that range from how to change a belt to water discharge and water pickup problems.
I have tried to gather together some different PDF files the will give you all the tools you need to figure out how to do almost every repair on your vacuum that you will ever need.
Check these guides out as they have a great amount of information in them.
Here is the Instruction or User Manual for the 7910 and the 8910 series machines
Here is the Instruction or User Manual for the 8920, 9200, 9300, 9400, series machines
Here is the Instruction or User Manual for the 9500 series machines
Here is a Troubleshooting Guide
Here is the Service Center Repair Guide
Hopefully you will now have the information you need to easily do the repairs on your machine. It will take some time to sort through the guides and find all of the information that pertains to your machine but in the end you will have the satisfaction of knowing that you were able to make the repair to your vacuum.
Vacuums Logo
Where can I get a repair manual for a Bissel carpet cleaner model #9400. Prefer a downloadable one.
Only from Bissel, but unless you are a repair shop they will likely not let you buy it.
Jan 25, 2017 | Bissell 9400 ProHeat Upright Wet/Dry...
MY BISSEL CARPET CLEANER IS NOT SPRAYING WATER ON THE CARPET-WHAT COULD BE WRONG?
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
heatman101
Sep 25, 2010 | Bissell Vacuums
water does spray out when using floor bissel proheat
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
heatman101
Mar 28, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
109,196 people viewed this tip
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
