PRINTER ERROR
The laser scanner speed is incorrect. X description: 1 = Scanner startup error 2 = Scanner rotation error
1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner.
52 Scanner Error The all-in-one has experienced an internal
hardware error.
1. Turn off the power by using the power
switch, and then wait at least 30
seconds.
2. If a surge protector is being used,
remove it. Plug the all-in-one directly
into the wall socket.
3. Check the FFC connection between the
formatter and the scanner.
NOTE Do not bend or fold the
FFCs during the removal or
reinstallation process.
4. Try connecting the product to a different
power source or surge protector.
5. Turn on the power and wait for the all-inone
to initialize.
6. If the error persists, replace the laser scanner assembly
If you scanner error 5 or printer hangs at scanner bulb warming up than the issue is with Scanning Assembly inside the printer and it is hardware issue.
most likely dust on the scanner optics causing scanner to be unable to go to home position. Solution would be to disassemble scanner assy and clean optics or replace scanner assembly.Note HP service manual says to replace scanner assy.
hp laserjet 3055 by scanner error 6
Solution: I found a very small piece of paper between the glass and the scanner housing. The lamp's seen that and sent the error message. Nobody find that little stucked paper and the "IT expert" sad: need to buy a new machine because he can't repair it. So, sometimes the solution is very easy just need some attention. :)
When powered on printer 3055 it gives error on control panel that "Scanner error 6 Trun off and then on " after several restart printer gives the same error what will be the problem
