Question about HP LaserJet 3055 All-In-One Printer
Printer Hp Laserjet 3055 giving error message 5
Printer / Scanner Hp Laserjet 3055 giving error message 5 when powering up printer
Posted by bikovacs on
  • 1 more comment
  • Anonymous Apr 29, 2009
    Carta non prel.
    Premere [x]
  • MTreeBandit May 11, 2010
    Just 5? No other message is displayed? The 3055 has a known problem (known to HP) with the formatter board and if your printer falls within the correct serian number range (or is in warranty), you should be able to get it repaird free of charge. Call HP's tech support (1-800-HP-INVENT) and find out if yours is one of them. The formatter is not too hard to replace, so if you can convince them to send you the board rather than take it to a service provider, you just remove the left side cover, and there's the formatter. Remove the cables connected to it (they are keyed so plugging them back in to the right places is easy) and 4 screws and put the new on in its place.
  • naeem qureshi Nov 13, 2013
    i want self formater card repair pelease tell me abot this problem
Anonymous
    Novelist:
  • 102 Answers
If you scanner error 5 or printer hangs at scanner bulb warming up than the issue is with Scanning Assembly inside the printer and it is hardware issue.
Posted on Jul 02, 2009
Karl Wright
    President:
  • 1,653 Answers
HP 3055’s have a known problem with the formatter board and if your printer is in warranty you should be able to get it repaired free of charge. Call HP to clarify. If not get it to a repair shop for a quote.
Posted on Aug 30, 2009
How to solve scanner error 5 in HP LASERJET 3055?
The stepper motor controlling the scan arm is defective. Replace motor or entire unit.
Aug 07, 2014 | HP LaserJet 3055 All-In-One Printer
Please give explanation & soulation hp laser jet 3055 scanner error 6 \r\nWhy this problem are create in our printer
Scanner error #6 = DocOriginFind
Per the service manual here are the steps:
1 - Power Cycle the Machine (I'm sure you've done this already)
2 - Replace the Scanner Assembly (After replacing this if the message still appears then.. )
3 - Replace the Formatter and Line Interface Unit (LIU)
Oct 20, 2010 | HP LaserJet 3055 All-In-One Printer
SCANNER ERROR
Message comes with Printer Scanner Error 6
Turn Off Then on
Jul 21, 2010 | HP LaserJet 3055 All-In-One Printer
Hp laserjet 3055 has code 52 scanner error and wont print or copy
PRINTER ERROR The laser scanner speed is incorrect. X description: 1 = Scanner startup error 2 = Scanner rotation error 1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner.
Jan 15, 2010 | HP LaserJet 3055 All-In-One Printer
Scanner Error 6 Turn Off Then On
Dear Sir,
Welcome to Fixya
1.Switch off the printer, then remove all cables connecting to the printer but just the power cable.
2.Then press and hold the *(start/symoble) and 5 button togather and turn on the printer,continue holding the button till you see "perment storage init" displayed and release the button.
3.Then at a given point of time the printer will ask you to change laguage,time,date etc.
if this does not sort the issue service is required.
I think it deffinately helps.If you have any problem regarding this issue leave a feedback we were happy to assist you
Have a Nice Day!
Oct 03, 2009 | HP LaserJet 3055 All-In-One Printer
HP 3055 model scaner problem
i want repair HP laserjet 3055
Scanner error 6
Sep 15, 2008 | HP LaserJet 3055 All-In-One Printer
HP Laserjet 3055 with "scanner error 6 - turn off and on" error
hp laserjet 3055 by scanner error 6
Solution: I found a very small piece of paper between the glass and the scanner housing. The lamp's seen that and sent the error message. Nobody find that little stucked paper and the "IT expert" sad: need to buy a new machine because he can't repair it. So, sometimes the solution is very easy just need some attention. :)
Apr 27, 2008 | HP LaserJet 3055 All-In-One Printer
Hp 3055 laserjet scanner problem
When powered on printer 3055 it gives error on control panel that
"Scanner error 6 Trun off and then on "
after several restart printer gives the same error
what will be the problem
Dec 20, 2007 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
2,429 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
