What is the meaning of this code error and how can i fix it myself (if possible)
Flatbed scanner is bad replace whole top half p/n q6502-60116 approx. $150 - $200
Scanner error 2 on hp laserjet 3055
-The "Scanner error 2" is a common problem on the HP Color LaserJet 2820 and 2840 series printers.
-The general advice is to turn the printer on and off, and see if the error resolves.
- If the "Scanner error 2" keeps coming back, you should replace the flatbed scanner assembly.
-The "Scanner error 2" usually triggers when the scanner's drive motor fails.
Regards,
Rachel Gomez
Scanner Errors: Before going for a new scanner assy. trim by an mm both the edges of the Flat Flexible Cable between the formatter and scanner and refix. Replace this cable if problem not resolved. If replacement is still required, look for pulled out working scanners on the web.
SOURCE: 52 scanner error on HP Color Laserjet 2840
The device has experienced an internal
hardware error.
Recommended Action
SOURCE: Scanning on HP 3055 printer/scanner/fxx doesn't wrk with vista
I am unable to scan in pdf format under vista window
SOURCE: Printer Hp Laserjet 3055 giving error message 5
If you scanner error 5 or printer hangs at scanner bulb warming up than the issue is with Scanning Assembly inside the printer and it is hardware issue.
SOURCE: hp laserjet 3055 scanner error 6
Hi sumittaneja0:
Try these steps.
52 Scanner Error The all-in-one has experienced an internal
hardware error.
1. Turn off the power by using the power
switch, and then wait at least 30
seconds.
2. If a surge protector is being used,
remove it. Plug the all-in-one directly
into the wall socket.
3. Check the FFC connection between the
formatter and the scanner.
NOTE Do not bend or fold the
FFCs during the removal or
reinstallation process.
4. Try connecting the product to a different
power source or surge protector.
5. Turn on the power and wait for the all-inone
to initialize.
6. If the error persists, replace the laser scanner assembly
Hope this helps
SOURCE: Hp 3055 laserjet scanner problem
When powered on printer 3055 it gives error on control panel that
"Scanner error 6 Trun off and then on "
after several restart printer gives the same error
what will be the problem
If
you need more help come back.
Post
/ thumbs / testimonial are welcome!
