Question about HP LaserJet 3055 All-In-One Printer
Laser jet 3055 scanner error 6
I have problem in my hp laser jet 3055 scanner error 6
i clearn the glass but my problem not solve
Posted by anildhirain2 on
Anonymous
  • 160 Answers
Generally, Error 6 is a failure of one of the PCA boards and the unit requires service.
Posted on Apr 20, 2010
  • Anonymous Apr 20, 2010
    Before you panic however,
    Check for a little piece of paper under the beginning
    of the scanner glass, at the right front corner, a particle of paper
    in that position causes this message in the 3055.
    ***Don't forget to VOTE for the guys who take an interest in helping!
How to solve the hp laser jet 52 scanner error
there are three usual faults that cause this
1. the scanner is unable to locate home position- remove the scan glass/ clean and lubricate all rails
2. the ribbon cable has open circuit on tracks- replace the ribbon cable connecting the scanner to printer
3. the printer main PCA has failed and cannot control the scanner- replace main PCA
Dec 17, 2013 | HP LaserJet 3055 All-In-One Printer
Please give explanation & soulation hp laser jet 3055 scanner error 6 \r\nWhy this problem are create in our printer
Scanner error #6 = DocOriginFind
Per the service manual here are the steps:
1 - Power Cycle the Machine (I'm sure you've done this already)
2 - Replace the Scanner Assembly (After replacing this if the message still appears then.. )
3 - Replace the Formatter and Line Interface Unit (LIU)
Oct 20, 2010 | HP LaserJet 3055 All-In-One Printer
Please give explaination & soulation Scanner Error 6 hp laser jet 3055
Please refer to this post
http://www.fixya.com/support/t6483898-please_give_explanation_amp_soulation
HP Laser Jet 3055 printer-52 scanner error?
Remove the top cover. The laser / unit is a black box.
Try www.partsurfer.hp.com
to purchase one.
Jan 15, 2010 | Office Equipment & Supplies
Scaneer error 6 turn off then on
switch off the printer, then remove all cables connecting to the printer but just the power cable.
-then press and hold the *(start/symble) and 5 button togather and turn on the printer.
-continue holding the button till you see "perment storage init" displayed and releas the button.
-then at a given point of time the printer will ask you to change laguage,time,date etc.
if this does not sort the issue service is required.
Oct 28, 2009 | HP LaserJet 3055 All-In-One Printer
Printer not working
Contact HP tech support for a replacement bulb (or a quote on one).
Jul 04, 2008 | HP LaserJet 3055 All-In-One Printer
HP Laserjet 3055 with "scanner error 6 - turn off and on" error
hp laserjet 3055 by scanner error 6
Solution: I found a very small piece of paper between the glass and the scanner housing. The lamp's seen that and sent the error message. Nobody find that little stucked paper and the "IT expert" sad: need to buy a new machine because he can't repair it. So, sometimes the solution is very easy just need some attention. :)
Apr 27, 2008 | HP LaserJet 3055 All-In-One Printer
Scanner Error 6
clean glass. switch off. clean the lightsource bulb. keep fingers off the glass when cleaning
Apr 17, 2008 | HP LaserJet 2840 All-In-One Printer
Document loaded showing 3055
Sensor flag would have got stuck, check adf paper presence sensor
Oct 09, 2017 | HP LaserJet 3055 All-In-One Printer
Hp 3055 laserjet scanner problem
When powered on printer 3055 it gives error on control panel that
"Scanner error 6 Trun off and then on "
after several restart printer gives the same error
what will be the problem
Dec 20, 2007 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
692 people viewed this question
Ekse
efs_perpends
efs_perpends
