Televison & Video Logo
Anonymous Posted on Oct 21, 2009
I have a RCA PROJECTION TV 52". TODAY IT JUST WHEN BLACK. I GO TO THE MENU AND IT IS DIFFERENT COLORS AND IN 3D. THE COLORS AR RED,GREEN AND BLUE. I HAVE ONLY HAD IT FOR ABOUT 3 YEARS. THE IS NO SOUND.
Anonymous
Level 1:
Problem Solver:
  • Contributor 2 Answers
  • Posted on Oct 22, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
Questions
Helped
852
Points
Why should I pay you. I could just call RCA for free.
We have a RCA D52W23 rear projection TV. Now the color looks like it is in 3D. A friend has the same problem a few years ago and bought a part on line and fixed it themselves. What is the part and where...
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Blue, red and green are separated and i cannot find convergence from main menu
You can get a repair kit with parts and instructions from www.TvRepairKits.com
2helpful
This tv have convergence problems,it dead.Red,green,blue misaligns colors,have colors shadows,3d colors pic like.All these problems are the convergence board have 2 STK convergence ICS some or all it resistors are dead.These parts must change to solved convergence problems.The shop will cost u $300-350 for parts and labors.
It seems that I am watching my TV in 3D.
im joel a simple electroncis tech. try to adjust the settings but it does'nt work the i think 3 color inside ( red,blue,green) is one or two of them is deffective.so the best solution try to go the expert tech nothing else
1helpful
My rca projection tv has blue and green images like a 3D picture would without your 3D glasses, a double vision image and no other colors
sounds like the sensors are out of focus and your red sensor isnt turning on. look in the back of the tv for a master reset button or in your menu screen some sort of "Flash focus" or "convergence". They will realign the 3 sensors.
The picture looks 3D
  • Screen looks 3D
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
Rca 7302rd5 56"hdtv tv looks like a 3d moive
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Red green and blue lines rca 52' rear proj.
your convergence powert supply is not working-
replace the supply or repair it
3helpful
2answers
Color misaligned in RCA P52927
Hi,sounds like the convergence power supply reg.has failed,when this ic fails the adj. projection tv leaves the menu,this ic is located on the board above the board with 6 heat sinks on it mounted on the black plastic,its the ic that is heawt sinked on this board,part number is 215530
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
