RCA P52939 52 in. Rear Projection Television
Problems with RCA P52939 52 in. Rear Projection Television?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
RCA P52939 52 in. Rear Projection...
Troubleshooting and Support
Solved Problems for RCA P52939 52 in. Rear Projection Television RSS Feed
View More Results for RCA P52939 52 in. Rear Projection Television
Questions and Unsolved Support Problems
Unsolved Problems for RCA P52939 52 in. Rear Projection Television RSS Feed
Answer
I can not see the adjust projection TV from my menu now on a RCA P52939 projection screen tv
Answer
52" rca projection big screen,got it in 02'. never had a problem till last night. will not... (More)
Answer
It's an RCA P52939. When turned on, you can hear the snow (not hooked up to any AV source), but... (More)
Answer
RCA P52939 Chassis PTK195S16B Was working fine for about 5 years, then all of a sudden fluctuates... (More)
Answer
My RCA P52939 52 in. Rear Projection is bowed into the center from the sides like an hour glass.
Answer
RCA P52939 screen goes warped, it warps upward toward the center and and downward at the sides and... (More)
Find a Manual
RCA P52939 52 in. Rear Projection Television Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
Tips & How To Guides for the RCA P52939 52 in. Rear Projection Television
Earn cash by writing Tips & How-To's.
It's easy!  (Learn more)
Mitusbishi shuts off instantly...
Most of the Mitsubishi rear projection sets made from about 2000 through 2006 have a self diagnostic check feature. It will indicate if there is a... written by SD Tech
Mitsubishi Green Blinking light of death
This information applies to Mitsubishi sets that have a Model number beginning with VS, WS, WT etc. It does not apply to the WD series of sets made... written by SD Tech
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W..,...
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W.., D56W.., D61W.. · Symptom: No Convergence, Picture is bowed and distorted,... written by johnnydiode
Samsung Color Wheel replacement!
This varies a little depending on model number of the set. Usually a bad color wheel will produce a high pitched sound or even a grinding noise; some... written by SD Tech
Sony KP51hw40 etc with Blue screen and or Shuts down
Many of these sets had problems with bad picture Tubes--they use a red, green and blue crt. Most commonly the blue gives troubles--The tubes are now... written by SD Tech
PANASONIC CONVERGENCE DO IT YOURSELF REPAIR
So many people ask me about this here are my Instructions if convergence will not adjust and or is skewed: PANASONIC CONVERGENCE... written by SD Tech
Solution for Video looking whiteish, dull, or too red
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D... written by Ecollier2012
Why my TV does not start up and remains in standby?
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also ensure that the fault is not coming from a faulty receiver... written by ginko
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for RCA P52939 52 in. Rear Projection Television
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Ratings for the
Find a Warranty
Specifications for RCA P52939 52 in. Rear Projection Television
Key Features
Screen Size
52 inch
Display Capabilities
Aspect Ratio
16:9
Remote Control
Remote Control
Universal
Image Quality
Velocity Scan Modulation
With VSM
Comb Filter
Digital 3-Line
Adjustable Color Temp.
With Adjustable Color Temperature
Audio Features
Audio Type
Stereo
Sound Leveler
With Audio Leveler
MTS Stereo
SAP / MTS Stereo
Secondary Audio Programming (SAP)
With SAP
Technical Features
Picture in Picture
With PIP
Sleep Timer
With Sleep Timer
Commercial Skip
With Commercial Skip
Screen Text
Channel Labels
With Channel Labels
Closed Caption on Mute
With Closed Caption On Mute
Dimensions
Depth
25.25 in.
Height
52 in.
Width
44.25 in.
Weight
256 lb.
Warranty
Overall Warranty
1 Year
Tube Warranty
2 Years
RCA Contact Information
Main support number580-634-0151
Describe your problem:
Top Projection... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
