My tv keeps shutting off at random intervals. It doesn't happen every day, but today it has...
(More)
My tv keeps shutting off at random intervals. It doesn't happen every day, but today it has happened six times. It doesn't feel warm to the touch, and I have vacuumed all the vents. How do I fix that or what is the problem?
My RCA M50Wh74S does not turn on at all. The blue light flashes when i plug it in the the wall and...
(More)
My RCA M50Wh74S does not turn on at all. The blue light flashes when i plug it in the the wall and then it turns off. I just replaced my lamp but im not sure what is wrong with the television.
formatting keeps changing from 16.9 format to zoom and 14.9 zoom automatically without request from...
(More)
formatting keeps changing from 16.9 format to zoom and 14.9 zoom automatically without request from remote
Repost .hd52w56.... Tried to change the three caps and still just blinks three times and off. Any...
(More)
Repost .hd52w56.... Tried to change the three caps and still just blinks three times and off. Any other suggestions... Also resoiderd the fly back. Can anyone get me the test point so i can check this.
the tv plays great when its on but if you cut it off it will not turn back on. when you press the...
(More)
the tv plays great when its on but if you cut it off it will not turn back on. when you press the power button the light comes and you can here the tv try to start but nothing happens
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
written by Ecollier2012
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Call 1-800-447-1700 Consumer Electronics Technical Dept. GE sold out to: Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034 I called this company...
written by jrleopards
I received a full refund for this tv, Monday Oct 6, 2008. Thomson had a courier pick up this tv at my home 2 weeks ago. Just call the numbers I have...
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
