I have 4 brother printer. Model MFC 7220 But the printer has same problem. It can print one page at a time. But for the next page it shows " No paper Fed" and then press start. I clean the seperator roller and tab. What should i do? let me konw please.
You do not necessarily need to replace the toner right away. The toner has 2 visible clear tabs when you are looking at either side of the toner cartridge. This is for a reader built into the unit to recognize that the toner is low. However, if you cover those clear plastic pieces with black electrical tape, you will be able to achieve an additional couple hundred prints and when the toner no longer prints on the page, you are definitely out of toner.
1. Go to the following link on a pc that has internet connection: http://www.brother.com/html/download/index.htm 2. Click on the "Printers/Fax Machines/DCPs/Multi Functions" link below the region closest to you. 3. On the next page, if your asked, Select your country and preferred Language. 4. In the "Search by Model" section enter your Model No "MFC-7220" without quotes and click search. 5. Click on the search result displaying your model no MFC-7220. 5. Click on "Downloads" (top option) 6. Select you Operating System (ex. Windows7) and Language from the lists. Click Search. 7. Click on the "Information & Download" link next to your preferred download. I suggest using the "Full Driver & Software Package" download since this will probably have all the bells and whistles for the Printer included in one easy download :) 8.Click the Download button at the bottom of the next page & then Accept the terms & conditions on the next page. 9. The Download should start once you accept the t&c's 10. Once downloaded, copy the Installation File that was downloaded onto a Flash Disk for easy access on the PC where you need to install the Printer :)
my brother mfc 7860 tells me i have a jam when i print envelopes only- there is no jam and will print the next 'page' fine- have to turn it on and off 4-5 times to get it to print one- any ideas anyone???
Hi there it may be the driver remove the printer driver then put it back in again it may work, an other thing is it the right driver for the windows you are using.
All The Best Pineworks
1. Take paper tray completely out of the machine.
2. Remove the rear cover, clean the paper pick-up roller.
3. Put rear cover back, put paper tray into machine.
4. Copy a blank page for paper feeding test.
