Brother Multi-Function Center  MFC-665CW All-In-One InkJet Printer
Problems with Brother Multi-Function Center MFC-665CW All-In-One InkJet Printer?
Troubleshooting and Support
Solved Problems for Brother Multi-Function Center  MFC-665CW All-In-One InkJet Printer RSS Feed Post a New Problem
Brother mfc 665cw connection error
My laptop & printer all indicate they are on the same network, yet the laptop tells me it is offline. No option to...
2 Solutions
nothing prints
all of my ink cartridges ran out so i only replaced the black cartridge when i try to print nothing happens what do i...
1 Solution
Not reading printer
I installed 5 new black OEM cartridges into printer, 3 in the last 24 hrs, "CORRECTLY", it keeps saying either...
1 Solution
windows vista
I have windows vista that does not support the p-10 printer what do I do now? throw it out. can anything be done
2 Solutions
Brother MFC-665CW
I dont have a manual and my fax keeps trying to answer home phone. How do I turn it off?
2 Solutions
Open line on the Fax
When you pick up receiver it is an open line. How do we clear this so the fax machine is working.
1 Solution
Brother MFC-665CW
I recieve 2 codes on printer screen. Unable to print 30 & unable to print 50, Printer is 5 months old. Can anyone...
1 Solution
Unsolved Support Problems
Unsolved Problems for Brother Multi-Function Center  MFC-665CW All-In-One InkJet Printer RSS Feed Post a New Problem
Brother MFC-665cw - Unable to scan
I receive a message that states "The scan failed because of a scanner hardware error. Feeder may be jammed. Please...
Post a Solution
Unable to clean 51
I am getting an error message stating "unable to clean 51" What does this mean and how do I fix it so my...
Post a Solution
refill instructions for cartridge LC51Y...
HELP I do not know which of the two ports I should fill to.
Post a Solution
out of memory
my fax machine is showing out of memory how do I clean up the memory
Post a Solution
Unable to print 50 error
Hi I have got 3 in1 MFC 665CW PRINTER but its failing to print giving the above message,Thanks
Post a Solution
needing exploded view
I am having an issue with the black ink not printing. I have cleaned it several times and still I get very broken...
Post a Solution
Brother 665cw 'UNABLE TO PRINT 50' Error...
I had a paper jam - cleared it and then got the "unable to print 50" error message. I have turned off (over...
Post a Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
PlatformPC, Mac
Technology (Detailed)Inkjet
Max Resolution (Color)6000 x 1200 dpi
Black Print Speed27 ppm
Output TypeColor Printer
Color Print Speed22 ppm
Printer TypeAll-in-One
System Requirements
Operating SystemApple MacOS X · Microsoft Windows 2000 · Microsoft Windows Millennium Edition · Microsoft Windows 98 Second Edition · Microsoft Windows XP Home · Microsoft Windows XP Pro x64
Technical Features
Form FactorDesktop
Connectivity TechnologyUSB 2.0 · Wireless · RJ-45 Network Adapter
Monthly Duty Cycle1,000 - 9,999 (Individual)
Monthly Duty Volume2,500 Pages
Status PanelColor LCD
Memory Card CompatibilityMultimedia Card · Compact Flash Type I · Memory Stick · Secure Digital (SD) · xD Picture Card · Memory Stick Pro
Direct Printing CapabilityPrint Photos Without a PC
Dimensions
Depth14.6 in.
Height7.1 in.
Width18.4 in.
Weight18.5 lb.
Media
Media TypeTransparencies · Plain Paper · Inkjet Paper · Matte Paper · Glossy Photo Paper
Max Media SizeLegal (216 x 356 mm, 8.5 x 14")
Total Media Capacity100 Sheets
Warranty
Warranty1 Year
Memory
Installed RAM32 MB
Networking
Networking Type10/100BaseTx · Wireless Network Adapter
Data Link ProtocolsEthernet · IEEE 802.11b · IEEE 802.11g
Multifunction Features
Copying Speed (Black)20 ppm
Zoom Range, Enlargement400 %
Zoom Range, Reduction25 %
Copy Speed (Color)18 ppm
Scanning Features
Scanner TypeFlatbed Scanner · Sheetfed Scanner
Scanner Resolution600 x 2400 dpi
Faxing Features
Modem TypeFax / Modem
Fax Speed14.4 Bps
Fax Features SupportedPC Fax · Color Fax · Automatic redial · Auto Fax Reduction · Distinctive Ring
Brother Contact Information
Main support number800-276-7746
Support FAX1-800-521-2846
Sponsored Links
Loading problems.
Top Experts
Ask Me
Mix-it-up Guru
159 solutions
Ask Me
ZenX Master
1 solutions
Ask Me
Freelady2 Master
1 solutions
Repair Service
Find Printer Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
