20 Most Recent Brother MFC-465CN InkJet Printer Questions & Answers
try cleaning the paper feed roller with isopropal alcahol
Brother... | Answered on May 18, 2019
If any of the ink cartridges need to be replaced the printer will not work. Also, if you are printing only black you will need to go into print properties and select black.
Brother... | Answered on Dec 03, 2017
buy a new one. there is no repair for print heads. and don't use refill inks.
not good for print heads
Brother... | Answered on Aug 01, 2017
My Brother printer MFC-465cn is doing the same thing. I have workaround / worked-around it by disabling bi-directional printing. Then print is clear. It's as if the head is shifting an irregular amount on the opposite direction, like the head is loose.
Same for copies. If I use the PC interface to make copies, I can set the copy printing to be mono-directional, then copies are clear.
Brother... | Answered on May 12, 2016
Sometimes you have to open it and then close it again, firmly. You could also try hard resetting your printer. NO PDF
Brother... | Answered on Jan 17, 2016
Brother has the software and drivers that came on the CD-ROM on their support site: http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us&lang=en&prod=mfc465cn_all . Select your OS and the language in the menus. Download the full software from the first link (at least on the Win7 drivers list) to use all of the features of your printer. If you download just the drivers, the buttons on the multi-function printer will not trigger any action by the computer. If you need the manual, the link is: http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_top.html?reg=us&c=us&lang=en&prod=mfc465cn_all . Again select your language.
However, any third party software that was on the disc will not be available. (The OEM copy of PaperPort SE with OCR was on the CD for Windows systems.) You'll need the original disc or to replace the software with the full version if you use it. (You would need OmniPage to replace PaperPort SE with OCR. PaperPort and PaperPort Pro do not include OCR capabilities.) There are other programs that do this as well.
I hope this helps.
(Brother does not offer replacement install CDs for printers.)
Brother... | Answered on Dec 05, 2015
1-877-BROTHER (877-276-8437)
M-F, 9:00am to 9:00pm Eastern Time
Brother... | Answered on Jun 04, 2015
Error 49 relates to the print head drive voltage. It may just need the flat ribbon cables that connect the head to the main pcb reseating, but equally it may need the print head replacing (most likely).
An outside chance that the main pcb will need replacing.
In theory, all of these jobs are a task for an engineer. Brother UK (0870 830 400) can pass you on to a repair agent.
Brother... | Answered on Apr 02, 2015
most ink jet printers are not made for any type of volume of more than a couple copies a day. my advise would be to donate this one and purchase a LASER jet printer. the cost to fix this is more than what it is worth.
Brother... | Answered on Jan 05, 2015
1)Have you tried copying the data from Internet to word application
and then print the word document.
2) Otherwise uninstall driver and re-install it from here
http://www.siliconguide.com/drivers/device/1726/
Not sure what you mean by double printing.
Is it printing a ghost of what you print further down the page. Or is it mis-aligning the characters so it appears to have a shadow on each character?
Brother... | Answered on Aug 20, 2014
Is the line attached ? Press hook to listen for a line tone.
Brother... | Answered on Aug 01, 2014
I just had the same problem. Turn the printer off and back on again. It will reset itself.
Cheers!
TJ
Brother... | Answered on Jul 27, 2014
It sounds like it may actually be the "print head" which is what the carts fit into. These can and will go bad. Sometimes you can find replacements on ebay etc. But you need to make sure it is exactly the same part number. There could also be a number of other issues, the cart contacts could be dirty or damaged (another print head issue resolved by replacing), counterfeit cartridge, bad cart. These are the most common, but not the ONLY issues that can cause your problems. I'd check prices for replacement print head vs. new printer.
Brother... | Answered on Jul 18, 2014
The code is within the ink cartridge itself. If it is not a main brand cartarage, you may have th esame problem with both . I would suggest buying a main brand one .
heads can be cleaned with a tooth brush and alcohol. Dry well.
www.brother-usa.com
Brother... | Answered on Jul 13, 2014
Brother MFC-465CN InkJet Printer Logo
348 questions posted
James Cagle
James Cagle
Jim Keysor
ctnozil
View Most Popular
MFC Brother
  • MFC Brother
Most Popular Question
shows cannot print error 4f
  • Office Equipment & Supplies
