I have a Sony Handycam and I am trying to take tapes already recorded on the sony handycam (model DCR TRV740 NTSC) onto any other media for watching on my computer or tv etc...? is this possible?
SOURCE: Can't transfer recorded video to CD
This is a problem with the type of drives that are supported by the Picture Package software (assuming this is what you are using to transfer the video). This camcorder came with Picture package 1.0 which does not support quite a few drives (the entire list is available at www.ppackage.com). I think your drive will also fall under the same list of unsupported drives.
Regards,
san_chako
SOURCE: Memory Stick for the Sony Handycam DCR-DVD 105
This camera uses memory stick duo memory. If you refer to p. 31 of the user manual found here:
http://www.docs.sony.com/release/DCRDVD105-205-305.pdf
It is right beneath the strap.
Keep me posted. I hope you find this FixYa worthy.
Thanks,
Lee
SOURCE: Sony Handycam Dig 8 doesn't recognize tape when trying to record
If it has memory stick, Make sure your memory stick is in. Your memory stick is full. Delete the unwanted pictures from the memory stick or use a differnt biger memory stick.
I looked in the manual. It seems your camcorder does not have a slot for memory stick. But you may still save pictures on the tape. Here is the link to download the manual
http://www.docs.sony.com/release/DCRTRV140.pdf
Please read Page 40 "recording picture on the tape".
GOOD LUCK !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
SOURCE: Trying to transfer camcorder video to computer.
To transfer camcorder video to computer, you need the following:-
1. Firewire cable (it looks similar to the USB cable, but has very high speed capability)
2. Appropriate software/application.
If a firewire cable did not come with your camcorder then see that purchase one right away, ‘cause you will always need it for this purpose. Then you should have a video editing software like Adobe Premiere or Ulead installed on your system. Adobe Premiere is recommended for its speed.
Once you have these in place, all you need do is connect the camcorder to your computer via firewire, have your video editing application/program open, and simply playback. You will observe that the playback on the camcorder is at the same time being shown on the computer screen within the application. While the mini DV tape is playing back click on capture on the video editing application you are doing the playback from, i.e. Adobe Premiere, Ulead etc.
Testimonial: "OMG THANK YOU SSOOOOOOOOOOOO MUCH!!!!"
SOURCE: Hi i have just brought a sony dcr-sx30 handycam
It seems that your handycam does not support the memeory card u put in.
