20 Most Recent
Sony 4GB Memory Stick PRO Duo Memory Card Questions & Answers
I also have problem where all my photos were
Search online for "memory stick file recovery" programs.
Like reading through a book, page-by-page, because the Table-of-Contents is illegible, these type of programs will read through every file on the memory-stick, trying to "stitch" the pages back together.
4 gb jumptwist
at the command prompt type chkdsk X: /f /r where X is pen drive.If it doesn't work download the recovery tool here http://freeware-fix.blogspot.com/2013/04/usb-drive-is-unreadable.html
My sony memory stick pro
There should be a lock switch on the card, most likely on the left side. Slide the switch into the opposite position and see if this fixes the problem. If not, try formatting the card from your camera and then attempt to load it on to your computer.
My memory stick of 1gb
That means the memory card was corrupted. You need a memory card recovery to recover photos before seeing it. I recommend you use
Card Data Recovery, i can recover data from corrupted or damaged memory card.
Computer doesn't recognise memory stick pro duo 4gb
Hello Guys,
The computer sometimes doesn't recognize the
memory stick device due to corruption, there are numerous causes for memory
stick corruption for example virus attack, improper removal, wrong usage of the
memory stick device and many more. After such corruption scenario data are lost
from these devices, but luckily you can recover
memory stick files by using an
efficient recovery application like Yodot Photo Recovery. Apart from memory
stick the tool also recovers files from all other devices like memory stick,
hard disk, iPods, music players etc. Try using this tool to recover your
data from memory stick
