Sony DCR-HC26 Mini DV Digital Camcorder Logo
Posted on Jan 26, 2010
My sony DCR-HC26 TOUCH SCREEN NOT WORKING
Please tell me what to do?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 02, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
14922
Points
7
It's not exactly the same, but this website shows a pretty foolproof way on how to fix it on a different camera.
http://www.agoraquest.com/viewtopic.php?topic=33427&forum=32&start=10&select_page_number=2
i fixed the touchscreen on my hc26 with it on the first try. i put a piece of paper folded a couple times under the ribbon cable connections where it meets the screen (against the plastic frame for the screen, under the blue cable), and put a piece of cardboard against the circuit board to give it more pressure from that side. works like a charm!
  • Anonymous May 13, 2011
    I HAD THE SAME PROMBLEM, I GOT IT FIXED AT MATA CAMERAS, NO 86, 1ST FLOOR SP RD.BLORE 2 INDIA , MR VIJAY 9035871324. THEY DID THE REPAIRS IN 24 HOURS. GR8 SERVICE.
Anonymous
Level 1:
New Friend:
  • Posted on Mar 29, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
14922
Points
My handycam DCR-SR46 40GBup to 27hrs. recording(3Mbps)
hybrid HDDhard disk drive touch is not working
please help me
4 Related Answers
Anonymous
  • 15 Answers
  • Posted on Dec 30, 2010
SOURCE: touch screen no longer works on Sony DCR HC26
If the touch screen of the Camcorder is not working, pleasefollow the troubleshooting steps.
Please make sure that you're using fully charged batteries.
Turn off the Camcorder and turn ON again and check the operation.
Try resetting the Camcorder by pressing the reset button behind the LCD panel.
Note: In the above picture, 8 represents the reset button.
If the issue persists again, please perform LCD screen Calibration and check ifthat helps.
Please follow the steps below to perform the LCD Calibration
Perform a power resetting of the Camcorder. To perform power resetting, pleaseremove the battery pack, turn the Power switch to Play/EDIT/ON for more than 15seconds, turn the Power switch to OFF position and then reinsert the batterypack.
If the issue persists even after performing all the above-mentioned steps,service is required.
I hope this information will help you to resolve the touch screen issue of theCamcorder.
Anonymous
  • Posted on Jan 27, 2011
SOURCE: sony dcr-hc26 touch screen does
Sony dcr-hc26 touch screen does not work
Anonymous
  • 1812 Answers
  • Posted on Jul 23, 2011
SOURCE: touch screen stuck on set
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the LCD to the camera body and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Anonymous
  • 1812 Answers
  • Posted on Sep 23, 2011
SOURCE: sony handycam DCR-HC26 touch screen not working
This is usually caused by a defective LCD module or a defective flex cable that connects the LCD to the camera. I recommend replacing them both at the same time. The LCD / Touchscreen module is no longer available from Sony at an reasonable price for this Model. However, I have a limited supply of them in stock as well as an aftermarket supplier with hundreds of them.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have it repaired, please click HERE for a directory listing that suits your needs.
Sony Touch Screen in camcorder hc26 do not work. thanks
If the touch screen of the Camcorder is not working, please follow the troubleshooting steps.
Note: 8 represents the reset button on the above figure.
If the issue persists again, please perform LCD screen Calibration and check if that helps.
Perform a power resetting of the Camcorder. To perform power resetting, please remove the battery pack, turn the Power switch to Play/EDIT/ON for more than 15 seconds, turn the Power switch to OFF position and then reinsert the battery pack.
If the issue persists even after performing all the above-mentioned steps, service is required.
I hope this information will help you to resolve the touch screen issue of the Camcorder.
2helpful
My sony handycam DCR-HC26 is frozen on "clock
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the LCD to the camera body or the LCD module itself and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
9helpful
2answers
dcrhc26%20reset%20button.jpgdcrhc26%20reset%20button.jpgmoz-screenshot.pngmoz-screenshot-1.pngrsshajan_3.jpg
If the issue persists again, service is required.
Touch screen no longer works on Sony DCR HC26
Type of unit:Sony Handycam (DCR-HC26)I have a couple...1)when trying to insert a DV cassette,the door will not shut.2)The buttons on the touch screen won't work either.
The most likely cause for the buttons not working is a damaged or defective flexible ribbon cable that connects the LCD to the camera body and can be repaired fairly inexpensively. The tape mechanism is another story.
20helpful
2answers
I have a sony handycam dcr-hc26 that wont close the type door can you please help me ??
I have a sony handycam DCR-HC26. After loading in the DV cassette tape and the tape cannot get loaded in and therefore I can't close the tape door. Please help.
Thanks
3answers
1helpful
My touch screen buttons stopped working, and now I cant play back or even put footage on the computer. I try to click the touc screen buttons but it doesn't work. The recording and everything works fine,...
the flexwire is the problem of your camera and if all wiring be cut the next problem is the lcd monitor would not turn on...go to a service center for replacing or repairing the flexwire...
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
