There are 4 capacitors in your DM Module that have been known to go bad. They are located in the metal box that is on the left side of the set looking at it from the back. The capacitors can be changed with relative ease, but if you don't have any experiance in electronics, I would advise that you have an service provider do it for you.
Your monitor has a self-test feature. Have you tried using it? The link below will give you directions on how to do this. It will also give you information on common problems.
you need the V21 V19 dm repair kit which should take care of that issue for you. Its listed under repair kits at the following link http://servicemanuals.vstore.ca/
the kit contains the capacitors and instructions on how to do the repair.
Your minitors power supply is now damaged, probably from the power outage. I t will need to be repaired or replaced. Check the cost and benifits of both options and make a discision.
NSSMS
What does the light blink? Also look on the printed circuit boards right below the picture tubes and see if there is any fluid leaking on them. These are the first things we need to know.
I'm sorry there isn't. Answering machines like this have very little ROM memory. After a powersurge and outage like last night, it wiped the whole memory chip. You can try there support page. It's actually pretty good.
http://telephones.att.com/telephones_ui/support/index.cfm
I had power outage last night now corder at&t 1855 led's keep flashing keeps telling me about power outage before every new message. How do I get rid of the flashing?
