All Products > JVC > Projection Televisions
Problems with JVC AV-56WP74 56 in. Rear Projection HDTV-Ready Television?
jvc AV-56wp74 convergence
I saw in a previous post that you could post links to the parts and step by step instructions to fix this problem. My...
1 Solution
dcm
where is the digital convergence module located on the JVC av56wp74 56. I want to remove to take to repair shop to...
2 Solutions
convergence problem
Red convergence is concaved from left to right reset convergence and then did manual and cannot fix
1 Solution
Convergence issue with blue
My convergence is messed up on the blue color, I can manually set the red and green but not blue. When you use...
1 Solution
jvc av56wp74 rear projection tv
i think i have a convergence problem. the screen seems like it has double vision and the auto convergence doesn't help...
1 Solution
convergence with new chips
I had a friend of mine solder in new stk chips, now the top and bottom of the screen is bowed inward. The original chips...
1 Solution
jvc tv model av-56wp74
when I tried to turn my set on the speakers would pop in rythem and then stop,at this point the blue power light on the...
Post a Solution
JVC AV-56WP74 Please help wavy 3d
Hi you doing I have a wavy 3d picture on the right side of my tv i think the red light is causing this i dont know what...
Post a Solution
JVC TV TROUBLE
THE PROUBLEM IS MY TV JUST STARTED WORKING BAD ALL OF A SUDEN. THE PICTURE HAS WAVES TOWARD THE TOP OF THE SCREEN. THAY...
Post a Solution
jvc pos
i just got home turned my tv on and the pic is out of wack, tried to mannually do the convergence but i could only do...
Post a Solution
JVC AV-56WP74 PICTURE...
THE MENU DISPLAY IS NORMAL AND CENTERED. THE PICTURE, NO MATTER WHAT INPUT, IS SHIFTED RIGHT. ABOUT BY ONE THIRD. ANY...
Post a Solution
JVC 56TH INC. IArt Rear Projection
Our TV screen went blank then when it came back up it had red in the picture and we can't get it out of the picture how...
Post a Solution
JVC REAR PROJECTION TV MODEL AV-56WP74 ...
THE ENTIRE PICTURE IS SHIFTED RIGHT. MENU APPEARS NORMAL AND CENTERED. I AM THE SERVICE MANAGER FOR BOWEN TV AND...
Post a Solution
General tips to repair LCD flat panel and... - Written by IrishDruid
Pioneer Pro Elite Rear Projection TV with... - Written by srarfi
Specifications
Key Features
Screen Size56 inch
Display Format1080i (HDTV)
Digital TV StandardHDTV-Ready
Display Capabilities
Aspect Ratio16:9 · 4:3 Enhanced
Remote Control
Remote ControlMultibrand
Illuminated RemoteIlluminated
Image Quality
Velocity Scan ModulationWith VSM
Comb Filter3DYC / 3D Digital
Adjustable Color Temp.With Adjustable Color Temperature
Audio Features
Audio OutputVariable / Fixed
Audio TypeVirtual Surround
MTS StereoSAP / MTS Stereo
Secondary Audio Programming (SAP)With SAP
Technical Features
Picture in PictureWith PIP
Parental ControlV-Chip
Sleep TimerWith Sleep Timer
Energy Star CompliantEnergy Star Compliant
Connectors
Rear Input ConnectorsS-Video x 2 · Composite x 3 · Audio (RCA) x 3
Front Input ConnectorsComposite x 1 · Audio (RCA) x 1 · S-Video x 1
Screen Text
OSD LanguagesEnglish · French · Spanish
Dimensions
Depth26.38 in.
Height54.63 in.
Width53.88 in.
Weight209 lb.
Warranty
Overall Warranty1 Year
JVC Contact Information
Main support number(800) 252-5722
Email supportproinfo@jvc.com
Sponsored Links
Top Experts
Powered by
Repair Service
Find Projection TV Repairman Near You:
