Troubleshooting & Support
Hot Topics:
- buzzing sound
- lamp light...
- green light red
- green lines
- Picture dark
- digital board
- Temperature...
- lines
- reset
- lamp
- temp light
- timer light...
- color
- screen red
- picture freezes
- screen goes...
- Ballast
- color wheel...
- black line
- check fan
- noise
- white spots
- beep
- picture
- fuse
- green screen
- humming sound
- turns
- lamp standby...
- turns off
- View All »
Problems & Solutions
Replaced lamp light in Samsung HLT4675XS/XAA 1...
I have a model close to yours & mine did the same thing. Its an easy fix the problem is its over heating. Unplug the tv take all the...
Samsung HL-S5086W 50-Inch TV comes up and turns on
you have a bad lamp , lamp need to be replace
the tv gets fuzzy after warming up and makes noise
Bad Color Wheel. Samsung Parts 1-800-627-4368
Our Samsung DLP TV was working fine when all of a
I would change the color wheel first since it is the least expensive. There are several on Ebay from the part number you mentioned. While in...
My Samsung model HLR4667WX/XXA is
It is easy; just look for a video on you tube and with a screwdriver and some care you can fix replace the color wheel yourself. I replaced...
My SAMSUNG DLP HLT5675SX TV seems to develop
my tv samsung hl-t5675s have lot dots how can i fix it
on and off
I have the same problem and am looking for a fix too. Have you fixed yours yet?
Sanding plasma tv make clicking
Hi, The ' clicking noise ' and no picture is highly suggestive of ' power supply ' on this set.You need to open the TV and...
My Samsung DLP 5668 displayed a "Check Fan...
Hello Do you see the timer and standby light blinking along with this message. If so colling fan inside it is not operating properly. The...
I have an HL- t50756
Try to reset the lamp timer. To do this get the remote first shut off the TV. Then on the TV remote (not cable remote ect) press MUTE then...
Samsung DLP tv has horizontal scrolling green and
Hi, was there a solution posted to this problem? I have the exact same problem and would really like to some help on. Thanks so much.
Have a loud high pitched humming noise coming from
Check below image that shows color wheel location, need to remove lamp housing on right side to take out color wheel in light engine. Visit...
Samsung dlp has dark picture?
It sounds like your lamp is about to die out,this tv lamps are good for 6000-8000 life hours witch is a average time of 2-4 years old and...
How do I change the color wheel on my samsung
Samsung's digital light projection (DLP) televisions use a spinning color wheel to create the colors that are seen on the screen. If the...
my 56 inch hi-def projection samsung tv turns off...
Ensure that the TV is off. It may be advisable to unplug the TV as well. 2 Using a Phillips screwdriver, remove the single screw affixing...
Unsolved Problems
I have a Samsung UE46D8000
I have a Samsug TV, its power light is blinking but no sound and no picture.How can I fix it?
TV cuts off
Replaced lamp light in Samsung HLT4675XS/XAA 1 year ago. TV is now turning off. The lamp light looks colorful but not...
would like to find out how to reset module for...
I HAVE A SAMSUNG HOME THEATER SYSTEM MODEL NO. HT T 2515. IT HAS WIRELESS TOWER SPEAKERS THAT CONTROL THE REAR. THE...
samsung dlp issues
have a 56" samsung dlp. black screen no sound. three blinking lights in the front. no other noise except the start...
43 inch model will not come on
43 in samsung tv will not come on flat screen led
SAMSUNG HLS5686WX/XAA CUTS OFF
TV CUTS OFF BY ITSELF AFTER TWO MINUTES
Upload a manual for Samsung DLP HL-P5663W 56" TV
Specifications
TopKey Features
Full Product Name:Samsung DLP HL-P5663W 56" TV
Screen Type:Flat Screen
Diagonal Screen Size:56 inch
Digital TV Standard:HDTV-Ready
Display Capabilities
Aspect Ratio:16:9
Aspect Ratio:4:3 Enhanced
Broadcast Format Supported:1080i (HDTV)
Broadcast Format Supported:480p (EDTV)
Broadcast Format Supported:720p (HDTV)
Broadcast Format Supported:480i (SDTV)
Remote Control
Remote Control:Multibrand
Illuminated Remote:Non-Illuminated
Image Quality
Velocity Scan Modulation:With VSM
Comb Filter:3DYC / 3D Digital
Audio Features
Audio Type:Virtual Surround
Sound Leveler:With Audio Leveler
SAP / MTS Stereo:SAP / MTS Stereo
Technical Features
Picture in Picture:With PIP
Parental Control:V-Chip
Sleep Timer:With Sleep Timer
Commercial Skip:Without Commercial Skip
Connectors
Headphone Jack:Without Headphone Jack
Rear Input Connectors:Component x 2
Rear Input Connectors:S-Video x 2
Rear Input Connectors:DVI x 1
Rear Input Connectors:Composite x 2
Rear Input Connectors:1 x D-Sub (RGB PC)
Rear Input Connectors:RF x 2
Rear Input Connectors:Audio (RCA) x 6
Rear Input Connectors:HDMI x 1
Rear Output Connectors:Composite x 1
Rear Output Connectors:Audio (RCA) x 1
Rear Output Connectors:RF x 1
Screen Text
OSD Languages:English
OSD Languages:French
OSD Languages:Spanish
Channel Labels:With Channel Labels
Speakers
Number of Speakers:2 Speakers
Speaker Power:2 x 15 Watt
Dimensions
Depth:15.59 in.
Height:37.89 in.
Width:57.36 in.
Weight:91.49 lb.
Warranty
Overall Warranty:1 Year
What's your problem?
Fix-O-Meter
443,929
443,929 people have viewed this product
- 2,202 people asked about this product.
- 747 people found solutions for this product.
- 56 people have added this product.
PIC SHRINKING...
How to Repair a...
Are You In Bad...
