Own a Samsung DLP TV 42 inch and white dots have started appearing on screen. TV about 3 1/2 years...
(More)
Own a Samsung DLP TV 42 inch and white dots have started appearing on screen. TV about 3 1/2 years old.
Good day, Our samsung DLP set has recently started shutting down the picture as we watch a movie....
(More)
Good day, Our samsung DLP set has recently started shutting down the picture as we watch a movie. The picture disappears, and a white patch of horizonal lines appear, which covers about 1/4 of the screen area. The sound continues for the movie, even though the picture is gone. We have times when the picure goes completely black, and the sound goes too. It can be corrected by turning off the set and waiting a while and again turning on the set. In advance thanks for your help. Don Back
having troublegetting sound fromm tv tosurround system im hooked up from audio out on tv to audio in...
(More)
having troublegetting sound fromm tv tosurround system im hooked up from audio out on tv to audio in on my panosonic surround system
there are spots on the tV that are tiny white dots. It appears that some of the tiny bulbs have...
(More)
there are spots on the tV that are tiny white dots. It appears that some of the tiny bulbs have burned out and I wondered if it can be fixed. There are about 5 or six scattered across the screen.
i removed the color wheel and it is missing a piece. so i obviously need a new wheel. i dont know if...
(More)
i removed the color wheel and it is missing a piece. so i obviously need a new wheel. i dont know if the lamp is bad. how can i see if the lamp is good and the olor wheel wasnt the only problem?
Samsung HLR5064W - Replaced the color wheel and now there is a Green/Blue cast over the screen....
(More)
Samsung HLR5064W - Replaced the color wheel and now there is a Green/Blue cast over the screen. Called Samsung to troubleshoot and they want to send a service person! If I could figure out that the problem was the color wheel in the first place and figured out how to istall it, theres got to be a way I can fix this too! HELP!!!
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
written by Ecollier2012
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Call 1-800-447-1700 Consumer Electronics Technical Dept. GE sold out to: Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034 I called this company...
written by jrleopards
I received a full refund for this tv, Monday Oct 6, 2008. Thomson had a courier pick up this tv at my home 2 weeks ago. Just call the numbers I have...
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
