2 symbols, bottom left 4 inches from left corner, look like a revolver, just appeared, won't go away.
SOURCE: Panasonic PT-53WX54 curved bottom
As stated by mastermind10, this is a convergence problem that you can fix yourself if you can solder. If you open up the back you should see a couple of large black ICs marked STK392-110. These are the convergence ICs. Try resoldering the pins on these ICs first. If that does not resolve the problem, replace the ICs. They can be obtained on the web for about $20-$25 each.
Keep us posted.
Dan
SOURCE: the symbols on the dashboard: what do the red and blue symbols
This is Letting you know that your Windshield Washer Reservoir is Low or empty. Please Rate My Response! Thanks!
SOURCE: Random Symbols on Pages I print
This sounds like a corrupt print driver. Try uninstalling and reinstalling the driver.
SOURCE: Meaning of Symbols on Hd rack?
If the server is configured with split SCSI channels these indicate which bays are part of each of the two channels. The common use for this would be to use the split with two drives for a RAID 1 system drive and the remaining four for RAID 5 data or in some cases two sets of RAID 1.
SOURCE: curved picture top an bottom
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly.
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
