Question about Garmin Nuvi 680 GPS Receiver
Show charging symbols
Please show the charging symbols
Posted by Paul Marshall on
SHARCNET-USA
  • Garmin Master
  • 2,130 Answers
Your question was posted under the Nuvi 680 GPS, so I am assuming this is the model that you have.
On the main screen, you will see a green battery status indicator in the upper right-hand corner of the screen. The battery is divided into 4 parts. Each part represents 1/4 power. So if you have one green bar, that indicates that the battery has 1/4 of power left. If there are 3 bars, that indicates that there is 3/4 power left.
When the unit is charging, you will see a yellow lightning bolt appear over the green battery status icon.
When the lightning bolt is not there, this means the unit is running off of the battery.
When leaving the unit to charge, press and hold the power button until you see that the screen says Charging Battery. A few seconds later, the screen will go blank to save energy.
Pressing the screen again later will either say Charging Battery or Battery Charge Complete.
Posted on Mar 27, 2013
Why does the battery level icon show only a "lightning strike" symbol?
Lightning Strike Symbol means that the battery is charging.
If it is shown even when it is not charging then your charging circuit needs to repaired. Just replace the charging IC not a very high cost. Might cost around 5-10USD.
May 24, 2014 | Amazon Kindle Paperwhite
My sony erricsson mobile shows always on net symbol (globe symbol) this causes reduction in battery charge and net usage charges. what do i do to disable that symbol and use it only if i wish
in some sony ericsson model symbol of net mean you have activated GPRS facility (like S500i) it dosent consume yourinternet charges, yes it can **** you battery but that depend on network bandwidth, if network is gud the no need to worry.
please dont forget to vote.
Aug 01, 2011 | Cell Phones
Hai there.... yesterday i bought new battery for my acer aspire 4520. Why the orange light keep blinking when the battery were charge???als0 there is no show the charge symbol on my screen??? I really...
when orange light is on it means it is charging and to know whether your system is charging just look at battery symbol where you will find a wire symbol on battery which show it is charging and when charge is complete orange light turns blue
Feb 15, 2011 | Acer Aspire One PC Notebook
Xperia x1 won't charge. The charging symbol will appear on the screen for a short period of time (perhaps 2 or 3 minutes) before disappearing a showing the full battery symbol. This shouldn't appear...
First try to replace the battery, a drained or low voltage battery won't charge up.
For infos on how to fix the Sony Ericsson Xperia X1 Not charging:
http://mobilephonerepairguides.blogspot.com/2011/01/sony-ericsson-xperia-x1-not-charging.html
Aug 31, 2010 | Sony Ericsson XPERIA X1 Smartphone
Computer symbol when charging my Garmin Nuvi 200
TRY SWITCHING GPS OFF WHILE CONNECTED. IF NOT DOWN LOAD NEW SOFTWARE AND WHEN FINISHED IT LEAVE CONECTED SHOULD SHOW CHARGING AND YOU WILL BE ABLE TO USE
Dec 18, 2009 | Navigon 2100 Portable GPS Receiver
HTC Touch Dimond displays Roaming symbol E beside Signal strength
yea i also have the same problem even though i have my data switched off nd no gps etc. wont i b charged for the e symbol meaning it uses data even thou i have data switched off? this is really weird someone please help us out. thanks
Jun 15, 2009 | HTC Touch P3450 Smartphone
Toshiba gigabeat MES60VK (60 GB) stopped working
There is a little battery cut of switch at the bottom of the device. You can unbend a paper clip and switch it off. Then switch it back on after a few seconds. Plug it back into the usb cable to charge it. It should work ok now.
Dec 26, 2007 | Toshiba gigabeat MES60VK Digital Media...
Garmin Nuvi 680 GPS Receiver Logo
364 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
John Egan
John Egan
Janelle Schoonover
Janelle Schoonover
Are you a Garmin GPS Expert? Answer questions, earn points and help others
