20 Most Recent Garmin Nuvi 680 GPS Receiver Questions & Answers
try Mouser or Digikey
Garmin Nuvi 680... | Answered on Nov 17, 2017
The touchscreen must be replaced. Please see here for more info.
SHARCNET USA Out of Warranty GPS Digital Camera Repair
Garmin Nuvi 680... | Answered on Aug 11, 2017
Garmin Express software through a PC connected via USB.
Garmin Nuvi 680... | Answered on Jan 29, 2016
Your question was posted under the Nuvi 680 GPS, so I am assuming this is the model that you have.
On the main screen, you will see a green battery status indicator in the upper right-hand corner of the screen. The battery is divided into 4 parts. Each part represents 1/4 power. So if you have one green bar, that indicates that the battery has 1/4 of power left. If there are 3 bars, that indicates that there is 3/4 power left.
When the unit is charging, you will see a yellow lightning bolt appear over the green battery status icon.
When the lightning bolt is not there, this means the unit is running off of the battery.
When leaving the unit to charge, press and hold the power button until you see that the screen says Charging Battery. A few seconds later, the screen will go blank to save energy.
Pressing the screen again later will either say Charging Battery or Battery Charge Complete.
Garmin Nuvi 680... | Answered on Mar 27, 2013
If you keep holding the button down it will go past the pre-boot mode and you'll eventually come to the calibration screen. Please see this link for more info:
http://www.sharc.net/discus/messages/6/77.html?1236709210
Also see this link on how to het your touchscreen replaced:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Garmin Nuvi 680... | Answered on Oct 10, 2012
Hook up your Nuvi to your computer and go to the Garmin site and download the latest driver software to the 680.
Garmin Nuvi 680... | Answered on Jul 09, 2012
It is common problem and there is no fix, sucks
Garmin Nuvi 680... | Answered on Jun 09, 2012
Thank you for contacting Fixya support.
In order for us to provide you the detailed troubleshooting or anything that can be done to correct your problem we need you to provide us further details about this issue.
Please do provide us the brand and model of your unit , how old is the unit and when did the problem started.
Garmin Nuvi 680... | Answered on Jan 08, 2012
The connection to the antenna is most likely broken.
This is one of the main issues with the flip up antenna on the nuvi 6xx models.
The unit could be sent to a repair depot, but would most likely cost more to fix than what it is worth considering the price of a new GPS in today's market.
Garmin Nuvi 680... | Answered on Nov 03, 2011
I would suggest you reset the unit, if that doesn't solve the problem, then you will have to update your nuvi.
Frozen nuvi is as result of software problem. So you either reset or update. Update helps to reinstall the operating system file of the nuvi, thereby, putting it back to order.
Performing a Standard Reset
1. Slide the power switch all the way to the left (with the Nuvi's screen facing you).
2. Hold the switch in the position for at least eight seconds.
3. Push the switch to the right to power the Nuvi back on.
Performing a Factory Reset
1. Turn your Nuvi off by sliding the power switch to the left.
2. Press your finger against the bottom right corner of the touchscreen. Hold your finger in this position.
3. Slide the power switch to the right to turn the Nuvi back on. Continue to hold you finger against the screen until you see the factory reset prompt. Tap "Yes" to perform the factory reset.
Follow the procedures below on how to update your garmin nuvi:
1. Plug one end of the USB cable into your GPS and the other end into your desktop or laptop computer. The GPS device will load the appropriate driver automatically, and a message on your GPS tells you that it is connected to your computer via USB.
2. Open your Internet browser of choice and type in the following web addres: "http://www8.garmin.com/support/collection.jsp?product=999-99999-27 "
3. Download the appropriate version of the software for your computer (Windows or Apple) and Install the WebUpdater by following the wizard (accept defaults).
4. Click "Start," "Programs," "Garmin" and " WebUpdater" to update your firmware and your maps. Periodically check and make sure your software is current.
Please let me know if non of the above solves your problem so that I can help you further.
Good luck.
Try performing a soft reset.
Disconnect the unit from any external power supply.
Depress the reset button behind the flip up antenna.
Reconnect the unit to the power supply and let it should work normally.
If the soft reset does not work, try performing a hard reset.
Caution: Performing a hard reset will erase all user information including favorites and bookmarks and restore the unit back to factory settings. Be sure to save any information before performing the hard reset.
With the unit off, press and hold the lower right hand corner of the screen while turning the power on until a pop-up appears. Press "Yes" to restore the unit back to factory settings.
Garmin Nuvi 680... | Answered on Sep 26, 2011
Most garmin nuvi satnavs take 4 hours to charge with a mains charger or a car charger. It takes 8 hours with a computer. There's a batter indicator on the screen that shows WHERE TO and VIEW MAP. It will probably only appear when the charger is disconnected if it's the same as other garmin nuvis.
You can get the manual in Adobe Reader format from http://static.garmincdn.com/pumac/nuvi680_OwnersManual.pdf
Garmin Nuvi 680... | Answered on Jun 14, 2011
There it should be a lock switch on top of the unit that prevents you from touching buttons by accident.
Garmin Nuvi 680... | Answered on May 19, 2011
Details on how to update your garmin satnav are at http://www.fixya.com/support/r5628920-update_garmin_satnav_maps
Garmin Nuvi 680... | Answered on Feb 23, 2011
Try giving the unit a hard reset, this is done by turning it off > place your thumb in the bottom right corner of the screen > turn the unit on keeping your thumb in the bottom right corner > let the unit power up unitll the message " Are you sure you want to erase all user data appears" > select yes.
This may fix your problem but you will lose all your favorite and info so only o this as a last resort.
Hope this helps!
Garmin Nuvi 680... | Answered on Dec 10, 2010
here is a link to change the battery whick is also how to remove the screws to open unit....
http://www.youtube.com/watch?v=4pbOknpt2Qo
Garmin Nuvi 680... | Answered on Dec 07, 2010
I will suggest you reset your GPS, to reset your gps, follow this steps, turn off your device. Press down on bottom right corner of the touchscreen, and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press Yes to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
Once the GPS unit is reset, remember to place the device outside where there is a clear unobstructed view of the sky for 15 to 30 minutes in order for it to requires fix to GPS satellites. with this, the problem should be rectify.
Garmin Nuvi 680... | Answered on Nov 27, 2010
Sounds like you need to re-calibrate your unit...
Turn unit off then back on.
Slide Power Key to the right ( lock )
Hold finger on screen for about 30 seconds until the calibration screen appears
Follow on screen instructions.
Garmin Nuvi 680... | Answered on Oct 30, 2010
Garmin Nuvi 680 GPS Receiver Logo
77 questions posted
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
View Most Popular
nuvi Garmin
  • nuvi Garmin
Most Popular Question
garmin 680 gps will not acquire
  • GPS
