SOURCE: L170 Canon Fax Sound and volume control issues
Sunds as though you have the handset that came with the machine attached to it and the handset ring volume is still on. To turn that off there are 2 black inset switches on the handset itself turn those down or off.
SOURCE: Error Code for Fax Canon L220
You need to service machine and may be your fixing unit is problem
> If that replace Fixing Unit
SOURCE: I have a Canon Faxphone
check the TX section
http://www.retrevo.com/support/Canon-L170-Multifunction-Printers-manual/id/1304dj679/t/2/
SOURCE: Fax will not grab paper
Ther is a separation pad that developes a divot caused by the feed roller. Simple fix. order a new separation pad. It's located under the top cover. Just move slowly and identify the latches that hold the cover down. Don't force anything.
Another possibilty. If a document was forcably pull out of the document area the "White paper bar above the scanner glass might have been jerked out of it's normal position causing a blockage in the path. Investigate this possibility before ordering parts.
SOURCE: We have a Canon Faxphone L170. Someone sent a fax
On the controll panel there is a diamond shape picture with a eye in it.press that bottom and clear the fax that you received.There is no other way.You will have to phone the sender and ask them to change the papersize settings on the fax machine.
