Jam in output bin - duplex area Error message
Jam
in output bin
alternates
with
Open
door and clear jam Description
Paper
jam in duplex reversing area Action
Clear the jam.
Press the (SELECT) button on
the control panel.
If the problem continues,
contact HP Customer Support Center for technical assistance at http://www.hp.com/support/clj2600n or see the flyer that came
in the printer box for additional contact information.
Jam in output bin - fuser area Error message
Jam
in output bin
alternates
with
Open
A
paper jam has occurred in the output bin near the fuser area. Action
Clear the jam.
the control panel.
This error is cause by either having your output paper bin full of paper or the flag sensor out of alignment where the paper comes out of the top. Look at the top f the printer where the paper comes out and you should see a black plastic sensor flag, it should move freely. If it is stuck remove the top cover above it and try to free it so it can move. Below is a picture of the printer with the output sensor flag circled.
Maybe the paper exit guide is stuck or loose. Here's an article on A "Remove Paper - Standard Bin" or a "Std Bin Full error" Is Appearing on an E250d(n), E350d, E352dn, or E450dn Printer. Just click on this link: http://bit.ly/aygJz1. Follow the instructions. Thanks
Here's an article in the Lexmark website on A "Remove Paper - Standard Bin" or a "Std Bin Full error" Is Appearing on an E250d(n), E350d, E352dn, or E450dn Printer. Just click on this link: http://bit.ly/do0N3V. Read thoroughly and follow the instructions. Hope this helps. But if problem persists, I strongly suggest you contact Lexmark Technical Support to further investigate the problem. Thanks.
Make sure that the exit flag is moving freely. It sounds like it is stuck in the up position or popped out of place. The flag is located on the left side of the output bin and should be hanging down
There is a small flip lever that monitors the paper output. If this gets stuck it will give this message. This is on the left side where the paper exits the printer. You may also have a bad sensor but most of the time it just gets stuck.
The Standard Bin Full message is refering to the main output tray for the printer. If you have nothing mounted to the top of the printer, then the standard tray is where the paper is exiting.
What the message is telling you the bin is full and it is not, most likley the failure is that the sensor (a piece of wire is jammed in the up position. Just release the wire and let it hang down. That should clear your message and let you start printing again.
