HOW TO SOLVE P21 ERROR IN KONICA BIZHUB C451
Replace the black image unit and run registration procedure
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: konica minolta bizhub 350
• The Fusing Roller Sub Thermistor does not
detect the required temperature within 30 sec.
after a warm-up cycle has begun; therefore, the
copier does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
Check that the H1[ fuser lamp] comes on when the Main Power
Switch is set to ON, and correct or replace as necessary.
Check that the H2 comes on when the Main Power
Check the installation of the TH1 and the TH2, and
correct or clean as necessary.
Check the operation of the TH1.
Remove CN80 (4P), and then check that the resistance
across CN80-2 and -3 on the Thermistor is
infinity.
5
Check the operation of the TH2.
Remove CN81 (4P), and then check that the resistance
across CN81-2 and -3 on the Thermistor is
infinity.
6
Check the continuity of the H1.
Correct or replace as necessary.
7
Check the continuity of the H2.
8 Change PU1 - -
9 Change PWB-A
SOURCE: I am having problem with my konica minolta Bizhub C-450 malfunction C-2257
Dear,
Let us know , what Code is display on your Minolta C450P. So that we can provide you the proper solution.
Takecare
SOURCE: error code when copying... C6103 on Bizhub C451
C6103 - Scanner overrun failure
The Scanner Home Sensor detects the Scanner at its home position during a period of time that begins with the time when a prescan command
and a scan preparation command are executed and ends when a home return command is executed.
SOURCE: REMEDY TO SOLVING ERRORS COF32 AND CO650 IN KONICA
to remove code "COF32" from your machine, simply change the developer with the new one.
code will remove.
wish you best of luck............
SOURCE: how to solve bizhub 211 code error c0650
C0650 Faulty scanner home position sensor • The scanner home position
sensor (PS100) does not go from HIGH to LOW when the
scanner motor (M4) is energized for a given number of steps
after the sequence to bring the scanner back to its
home position has been started at the end of a scan
motion and during re-shading. • The scanner home position
sensor (PS100) does not go from LOW to HIGH when the
after a scan motion has been started at the end of a
PS100 home check scan
