Hi:
I Form Afghanistan I have a Konica Minolta bizhub C451
Prablem is cod C-C172
Plise help me tanks for you.
Merikh Printing Co.
[email protected]
ERROR
code C- C172 solution
Yap, check the image controller setings, sawa
Hi martin_fynn,
I've never heard of that code before
Although, there is a C-B172 which is related to the Fax Option.
The only thing I can suggest is that you turn the machine off at the Main Power Button (not the little one on the side of the control panel).
Give it about 20 seconds then turn it back on again.
Sorry the advice is a bit lame :-(
Good luck.
Hi:
I devendra from agra (India) I have a Konica Minolta bizhub C451
Prablem is cod C-C172. plz help
Have you solved yours problem?
I've got the same problem on Develop Ineo+ 253 (aka Konica Minolta Bizhub C253).
Service manual doesn't cover this error. Machine hardware has been checked few times, firmware upgrade and downgrade (with HDD memory up/down, too).
Nothing helps.
There is no CC172 code in the factory service manual. Could this be a typo? That or you have a code that is not in the manual.
salar
shvan_aradn
