Question about Konica Minolta Bizhub C451/c550/c650 Toner Magenta A070330
Erreur P21 konica C650 - Konica Minolta Bizhub C451/c550/c650 Toner Magenta A070330
Norman J Weimar Jr
  • Konica Minolta Master
  • 6,960 Answers
Requires remove of the transfer belt and cleaning of the registration sensors located under the belt on the right side of the machine, with belt out requires knowing what lever to push to expose the sensor to clean them or the have them replaced.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on May 25, 2015
1 Related Answer
Anonymous
  • 167 Answers
SOURCE: Print Booklets with Konica Minolta Biz Hub C650 Printer
Select Print, and then "Properties"
Layout Tab - select Print Type: Booklet
Basic Tab - Select original size and then size of PAPER to be printed. 11x17 is standard 8.5x11 book when folded.
Finish Tab - select saddle stitch.
Thats it, easy as pie.
Posted on Feb 17, 2009
My copier can't print yellow color and p21 and p8 show on the screen. any clues
P21 & P8 are errors of yellow drum cartridge, replace yellow cartridge.
Aug 04, 2015 | Konica Minolta BizHub C650 Copier
Hi piz Error code P9 and P21 appears on screen and
check The Transfer Belt or it can be the Black Image Unit . (P9 & P21 normally: black Imaging unit) but P21 can also be refered to Transfer Belt). ..
Aug 08, 2014 | Konica Minolta bizhub C250 All-In-One...
C650
scanner home position code. Check the scanner located under the big glass. the scanner also has the exposure lamp. the bright light.
Jun 26, 2014 | Konica Minolta Minolta DI1610P Printer,...
Iam getting p21 c650 and developer
Color registration is off check the sensor under the transfer belt and mite want to have e tech run color registration procedure. black is the reference for the color registration having developer problems with black drum does not help
Apr 24, 2014 | Konica Minolta Bizhub C451/c550/c650 Toner...
Colour shift p21
registration have tech come out unless you know your way around a konica minolta machine need to check the sensor under the transfer belt
Mar 18, 2014 | Konica Minolta bizhub C250 All-In-One...
I have konica minolta bizhub c550,it showing me P21 and P6,what is the causes?and the black is not printing well
P6 : cyan image unit problem. P21 come after P6, and it's also too a cyan unit image problem. replace the cyan image unit.
Nov 18, 2013 | Konica Minolta Bizhub C550 Color...
What is the causes of p21 and p6 in konica minolta bizhub c550
replace the black image unit and clean sensors under the transfer belt
Error code p21
P21 is a colour registration test pattern failure - check transfer belt for damage and or dirt, clean if dirty if damaged replace unit, or possible print head fault
May 03, 2013 | Konica Minolta bizhub Office Equipment &...
Code erreur c3b04
what solution for the trouble code c-3B04 for c650
Apr 01, 2013 | Konica Minolta BizHub C650 Copier
Konica Minolta Bizhub C451/c550/c650 Toner Magenta A070330 Logo
154 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
