How do i reprogram after changing the batteries? it is used on a panasonic television.
<span style="LINE-HEIGHT: 115%; FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 22pt; mso-bidi-font-size: 10.0pt">RCA</span><br />
<span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 10pt">HI,</span><br />
<span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 10pt"> </span><br />
<b><span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 10pt">Direct Code Entry:</span></b><span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 10pt"></span><br />
<span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 11pt"><br /><b><span style="FONT-FAMILY: 'Arial','sans-serif'">Find the code your device.</span></b> </span><br />
<span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 10pt"><br />1. Press and hold "CODE SEARCH". </span><br />
<span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 10pt"><br />2. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed. </span><br />
<span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 10pt"><br />3. Enter the 3-digit code number. </span><br />
<span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 10pt"><br />4. Release "CODE SEARCH". </span><br />
<span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 10pt">5. With the device on, press another button to test (volume control/power button).If it does not work, repeat steps 1 to 5 with other codes which you have.</span><br />
<span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 10pt"><br /><b><span style="FONT-FAMILY: 'Arial','sans-serif'">follow the below steps to set remote without codes</span></b></span><br />
<br />
<b><span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 10pt">Code Search:</span></b><span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 10pt"></span><br />
<span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 10pt">1. Turn on the device you wish to control. </span><br />
<span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 10pt"><br />2. Press and hold "CODE SEARCH". </span><br />
<span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 10pt"><br />3. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed. </span><br />
<span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 10pt"><br />5. Press ON/OFF repeatedly until the device turns off. </span><br />
<span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 10pt"><br />6. When the device shuts off press and release ENTER. </span><br />
<span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 10pt">7. Try using the remote. If it does not function repeat steps 1 through 6</span><br />
<b style="mso-bidi-font-weight: normal"><span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 11pt">To Get The Code Please Go To Below Website</span></b><span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 10pt">:</span><br />
<a href="http://www.rcaaccessories.com/remotefinder/" target="_blank"><span style="FONT-FAMILY: 'Trebuchet MS','sans-serif'; FONT-SIZE: 10pt; mso-bidi-font-family: Arial">http://www.rcaaccessories.com/remotefinder/</span></a><span class="MsoHyperlink"><span style="COLOR: black"></span></span><br />
<span class="MsoHyperlink"><span style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: windowtext; FONT-SIZE: 10pt"><span style="TEXT-DECORATION: none"></span></span></span><br />
<span class="MsoHyperlink"><span style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: black; FONT-SIZE: 10pt"><u>You need to select the following information from the drop down list</u></span></span><br />
<span class="MsoHyperlink"><span style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: black; FONT-SIZE: 10pt"><span style="TEXT-DECORATION: none"></span></span></span><br />
<span class="MsoHyperlink"><span style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: black; FONT-SIZE: 10pt"><u>1.Model of the remote</u></span></span><br />
<span class="MsoHyperlink"><span style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: black; FONT-SIZE: 10pt"><u>2.Type of device to which you want to program(TV/DVD/VCR)</u></span></span><br />
<span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 10pt"><br />Thank you </span>
